1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
I know that my son's 1946 2 ton windshield cranks open. So what was the last year Chevy/GMC offered that?
I believe the 47 FIRST series was just like the 46's so my guess it that was the last year, 47 first.
Others may know different???
Yes, 47 1st series. The Art Deco style was the last as far as I know.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Thanks for the replies.
I am a big fan of the open windshield.
Jeffrey
Chevrolet (trucks) simply sold the 1946 truck into the 1947 calendar year. They did not use the term "first series" (as they did in 1955) - they simply sold them and registered them as 1947 trucks.
GMC did not use the term "first series" or "second series" in either 1947 or in 1955.
Yeah, the Art Deco was the last series for those water and wind leaking suckers.
My 46 GMC on Photobucket
On a steamy, hot summer day in stop & go traffic nothing is more refreshing than cranking the windshield open an inch or two
The cowl vent provides a lot of airflow, I can see how the windshield would help but it wasn't worth the leaks to me, so I removed mine.
Last year for crank start? 46-47 Art Deco again?
1946 Chevy 1/2-Ton
I think the trucks went to 53, I believe my 52 five window had one, never used it but I recall the hole...or am I dreaming
did some checking.. I was right for a change
Redryder pix
My Hotrod
Joker is right for the crank start. Why are we asking an unrelated question without a new thread?
Authorized Pest
Authorized Pest
Crank start. Crank windshield. Kinda like the computer putting in words it thinks you are going to say.
grin
~ Peggy M
1949 Chevrolet 3804
I am a cranking old man and I think the poster is trying to slip something by Cletis, kind of hard to do.. I just respond.
Redryder pix
My Hotrod
My son's 1946 2 Ton still has the hand crank support bolted in place on the upper inside of the bumper.
It can be repositioned on top of the bumper to support the hand crank.
Does that bracket need to be used to hand start the engine?
I have no inclination to do that though when we got the truck on of the 1st things we bought was a hand crank.
As mentioned the hand crank makes is easier to set points and adjust valves. Problem with our crank is too short to clear the bumper so the most we can turn the engine over is 180 at a time.
As long as you're not starting it with a crank too short. Sounds like a recipe for disaster if it kicks back.
