| | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | On my 1949 Chevrolet 1/2 ton I began reassembling the parking brake pedal and release mechanism yesterday. The release rod seems to be too short. I've installed the new leather floor seal, spring and felt seal. Parking brake will engage when flat bar is pushed all the way to the floor at the top, but then the release rod is too short and is not even close to the release bracket hole. Are there different lengths of release rods? The release rod measures 16 inches in length. What length rod do I need?
Pedal bushings...Re-attached the brake and clutch pedals yesterday. After installing the pedals, I noticed that the clutch pedal has a lot of side to side play in it. The brake pedal is snug. I read in a few posts that the pedal bushing don't fit and have to be modified. Does anyone make pedal bushings that fit properly without machining? Is it possible just to replace the clutch pedal bushing on the truck?
Any suggestions and advice would be much appreciated.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Anybody have a photo or drawing of the clutch and brake pedal assembly and parts?
Tim
