5 members (Hawkman, Peggy M, Otto Skorzeny, BC59, 1 invisible), 178 guests, and 3 robots.
Topics128,078
Posts1,056,057
Members48,433
#1166714 05/24/2016 6:02 AM
Hey all,
Im removing the front end to install my mustang ii kit. Ive been able to unthread the metal brake line but I can't seem to disconnect the rubber line.
https://goo.gl/photos/V7DmQq77B5aD7NTU7
Tips are welcome!
1955.1 Chevy 5 window 3100
Instagram - @1955.1chevy
That light gauge L-shaped piece of metal pulls out to release the hose. It has a groove in it that holds the hose fitting in place. There are no threads if you're trying to turn the hose fitting to unscrew it. Grab the L-shaped metal with a pair of pliers and pull. A screwdriver prying between the hose fitting and L will help get it started.
That did the trick. Thanks! Mine were covered with 60 years of gunk so I couldn't quite see how they worked. Makes sense now smile
