| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | Hey all, Im removing the front end to install my mustang ii kit. Ive been able to unthread the metal brake line but I can't seem to disconnect the rubber line. https://goo.gl/photos/V7DmQq77B5aD7NTU7Tips are welcome! Thanks
1955.1 Chevy 5 window 3100 Instagram - @1955.1chevy
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | That light gauge L-shaped piece of metal pulls out to release the hose. It has a groove in it that holds the hose fitting in place. There are no threads if you're trying to turn the hose fitting to unscrew it. Grab the L-shaped metal with a pair of pliers and pull. A screwdriver prying between the hose fitting and L will help get it started.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | That did the trick. Thanks! Mine were covered with 60 years of gunk so I couldn't quite see how they worked. Makes sense now
