0 members (),
95
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Rewiring my 46 1/2t, and I have come to the headlight switch. All the wires (original) have been cut. The switch appears to be the original Delco Remy 1995040 switch. Does anyone have a wiring schematic for this switch? I have a picture, but don't have a way of posting it.
Thanks for your help.
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Steve, Try this. 46 Wirring Diagram Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | I've got that, but what I'm looking for is which wire goes to which lug.
Steve
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The factory assembly manual should show that. It was what I used on the 48 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've got to ask this question....on the AD reproduction light switches I've seen have information stamped on the face/back of the switch. I just changed my switch on the 52 panel last night and it is labeled at each post......but it is hard to see.
...but the repop's for the 46 may not show that??
If your 12V and using this repop switch #EL60 from Carter you an see the labeled post. Click on the image to make it bigger.
http://www.oldchevytrucks.com/cart/index.asp?cat2=9764&path=1934+%2D+1946+Truck+Parts%2FElectrical%2FSwitches
| | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | The 46 switch has no marking, that I can see. Also my service manual does not show the lug connections. Anyone have a page form the 48?
Steve
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | That's what I'm looking for. Thanks for the help.
Steve
Steve
