| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 49 | 1951 1/2 ton (stock). Steering felt loose. Crawled under and found the castellated nuts attaching the pittman/draglink to the wheel cyl. had play. I was able to remove the cotter and tighten the top bolt but the lower just spins. Before I do something stupid. What is the correct tightness and how to stop that bolt from spinning. Pic of bolts on Instagram here >> https://www.instagram.com/p/BErDEbmyFN7/TIA | | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | These are normal bolts, you have to get to the back side to get a wrench on them. By the way, those bolts are the steering arm mounting bolts.
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | What size are the bolts? Assuming they're Grade 8 (which they should be for a steering system) a 7/16" diameter bolt with a 5/8" head should get 65-70 ft/lbs. 1/2" bolts (3/4" head) get 90-100 ft/lbs. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you pull the hub/drum off you can put a wrench on the head of the bolt to keep it from turning. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 49 | If you pull the hub/drum off you can put a wrench on the head of the bolt to keep it from turning. Ding ding. That makes sense. They are way way too loose. I'll get her on jackstands this week and check both sides. 65-70 ft/lbs I might need a bigger torque wrench. I'm setup for bikes not cars. | | |
