1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | My 40s are in pretty sad shape, anyone paint em? I've used POR15 type paint before, would it work, or would Rustoleum be OK? Any inexpensive suggestions, its is not a show truck but deserves better than the pits it shows! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Cheap? Try the rustoleum.
....is there someone close by that does powder coating. I'd think that would be nice and from stuff I've had done powder coating them would be T O U G H for a long time. | | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Powder coating is expensive her-I'm undecided at this time. Started to install the door handle ferules today- along with installing the side glass. I have new rubber/steel channel/whiskers too, but right off the bat, I found out the hole for the handle in the passenger door is not large enough for the ferule. Looks like someone has worked on that hole before. Now I'll have to carefully try and open it up some before I try pressing the new ferule in (fr China- its very light). I ordered the windlace for the glass, and its one piece, but does not cover the whole channel from bottom w/glass down to the top. I'm under the impression that the windlace does not attach to the top of the door frame- other has stated that and I'm pretty convinced- plus I dont have enough to do it anyway!
| | | | | Joined: Sep 2010 Posts: 1,714 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,714 | Powder coating at home can be inexpensive. H/F sells powder and the application gun. Any heat source 'like a gas grill' over about 400 degrees will set the powder. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | How about Rustoleum spray paint? Easy to touch up or redo whenever you want... Just get the hard hat can...it's the best aerosol paint you can buy. | | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I had some Krylon satin NICKEL that looks nice with my semi gloss paint on the cab. I'll have to try the hard hat can- have used the other type many times. George | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If your handles are pot metal, as most I have seen, then powder coat will not work for you. I have done powder coating in the past and it has failed on pot metal. When the part get heated to melt the powder the pot metal out gasses and you get pin holes all over the part.
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Thats good to know for everyone! I love the Satin Nickel I used, now if I could get the windows glass to stay in its track! Whats the trick? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | "Burrpenick", Start another thread on your window problem. Several of us have dealt with it. Be to to tell us why it is jumping out and where in the up/down cycle.
