4 members (Grizzly 34s, 66flea, Otto Skorzeny, Hanks custodian), 81 guests, and 2 robots.
Topics128,159
Posts1,056,900
Members48,458
My 40s are in pretty sad shape, anyone paint em? I've used POR15 type paint before, would it work, or would Rustoleum be OK? Any inexpensive suggestions, its is not a show truck but deserves better than the pits it shows!
Cheap? Try the rustoleum.
....is there someone close by that does powder coating. I'd think that would be nice and from stuff I've had done powder coating them would be T O U G H for a long time.
Powder coating is expensive her-I'm undecided at this time. Started to install the door handle ferules today- along with installing the side glass. I have new rubber/steel channel/whiskers too, but right off the bat, I found out the hole for the handle in the passenger door is not large enough for the ferule. Looks like someone has worked on that hole before. Now I'll have to carefully try and open it up some before I try pressing the new ferule in (fr China- its very light). I ordered the windlace for the glass, and its one piece, but does not cover the whole channel from bottom w/glass down to the top. I'm under the impression that the windlace does not attach to the top of the door frame- other has stated that and I'm pretty convinced- plus I dont have enough to do it anyway!
back yard wrench turner
Powder coating at home can be inexpensive. H/F sells powder and the application gun. Any heat source 'like a gas grill' over about 400 degrees will set the powder.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
How about Rustoleum spray paint? Easy to touch up or redo whenever you want...
Just get the hard hat can...it's the best aerosol paint you can buy.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
I had some Krylon satin NICKEL that looks nice with my semi gloss paint on the cab. I'll have to try the hard hat can- have used the other type many times. George
If your handles are pot metal, as most I have seen, then powder coat will not work for you. I have done powder coating in the past and it has failed on pot metal. When the part get heated to melt the powder the pot metal out gasses and you get pin holes all over the part.
Thats good to know for everyone! I love the Satin Nickel I used, now if I could get the windows glass to stay in its track! Whats the trick?
"Burrpenick", Start another thread on your window problem. Several of us have dealt with it. Be to to tell us why it is jumping out and where in the up/down cycle.
