7 members (HandyAndy, RoadsScholar, Wayne67vert, Peggy M, moparguy, ESum, 1 invisible), 69 guests, and 1 robot.
Topics128,211
Posts1,057,467
Members48,471
I found an original 1960's PS pump and brackets. The hoses are wrong. The PS pump and brackets came out of a car with the PS gear box INSIDE the frame and my PS gear box is OUTSIDE the frame. Besides that, the hoses are probably too rotten to use anyway.
I have the correct fittings from my 1974 gear box and the correct PS pump fittings too. All I really know is one side is low pressure so I guess that just uses a hose clamp. Can a shop make me a new high pressure hose? What kind of shop should I look for?
Some NAPA stroes can make hydraulic lines or just search "hydraulic hose" in your area.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Not only NAPA but a lot of times an exhaust shop will also make hoses. There is a place here in Spartanburg called Hydradyne that has hundreds of fittings and can make all kinds of hoses....it'll give you and excuse to check your gas mileage smile
If you're in farming country most implement dealers and some of the farm supply type stores can make them.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Good advice is posted above.
Try to find a hydraulic hose supplier in your area.
One company in my area was quite rude to me, but another company, Omni Hose, Inc., repaired and assembled about 12 of the hoses for my COE - at a cost a little higher than the cost of the fittings.
You might find some leads in this search-result.
NAPA and O'Reilly's make them to order.
Thanks for the replies. I'll soon have the PS pump installed so this should be getting done by middle of May. Not sure how I will route the hoses but shouldn't be too difficult. Where to acquire the hoses was one piece of the puzzle I had not figured out yet.
Jay, as you will find out, not all major parts store do the same all over the states as with everything else. Around here O'Rielly and NAPA do not....at least not in my town, which is why I mentioned Hydrodyne. They may be a chain and close by???
Alvin,You feelin slighted by this?
just kiddin
I find it hard to believe outfits as big as they are wouldn,t offer similar services thru the entire system.
Here on The Island,We are blessed with
Moreland Hose,
Long Island Truck Parts,
allsysemsbrakeservice.com
to name a few.
Never had an O,Rielly,s(don,t think theres any in NY) and 3 NAPA,S folded in this area in the last Year.
Pep Boys,Advanced Auto and Auto Zone have pushed them all out not to mention all the old Mom and Pop Machine shops/Auto stores
steve sr.
steve sr, have no fear my man. I have a very touch skin! I was actually saying that for Lugnutz benefit as we are friends and the stores I mentioned usually have one on every corner which means there is no need for them to put "some" services in every store. I always try to do local but as you mentioned, some of the great local stores are being pushed out. Advance Auto recently bought up CARQUEST but for some reason NAPA seems to hangon......and I mentioned this sometime ago that the counter help at NAPA are "almost" always brighter, meaning mechanically inclined, to know more about parts and what is going on than the rest put together and they are usually older, more mature, and stay on the job a lot longer!
Not all...but most in my neck of the woods.
If you have them in your area, Tractor Supply might be able to make them. I won't speak for all of them, but the one I have locally does make hydraulic hoses.
Bill Burmeister
Bill I Wish We had a TSC in this area,Maybe Upstate somewhere but None downstate.
Fix the link above to
allsystemsbrakeservice.com
