4 members (klhansen, jay d, jmoore, 1 invisible),
129
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Now that the metal work and rust repair is finished on the 49 I am at the point of locating a pair of front seats. The plan is to use the burb for long distance travel and adventures - and I no longer have the stock seats.
I replaced the entire front floor section with a new floor without the stock riser.
Suggestions? for seats that fit, tip and comfort? I did a search and found some suggestions but, wondering what more of the others have done to modify and improve comfort and safety.
tom
| | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | I've used late 90s Chrysler van buckets & captains chairs. They fit re viewing height, easily bolt to my flat floor and offered all the options: power adjustments, heat & leather. And they were not overly expensive and in excellent shape. --54CarryAll | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i used seats from a 96 2 dr tahoe. in my 66 suburban. the passenger seat will slide farther forward to give more room to get in the back on the 2dr than the 4dr | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Tom
I agree w the guys above. I also did the flat floor and used Chevy truck seats . My only adder is Depending on where they match up on the floor use a wide stiffener under the floor so they won't pull to in case some idiot pull out in front of you.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I like my old trucks to look as they did originally.
I (and my passengers) pay a very dear butt-pains penalty on long trips, even with my newly reupholstered and well-padded original seats.
I'll be jealous of you. | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | I like the GM seats with the seat belts built in, I'll be looking for 4 captains and a small bench for my burban. | | |
