Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Hotrod Lincoln, crenwelge), 104 guests, and 5 robots.
Topics128,281
Posts1,058,467
Members48,490
#1157282 03/28/2016 5:48 PM
This may have been addressed before. Rebuilding the front spindle hubs on a 1951 3100. Between the flange that goes on the backside and the hub assembly, there is a gasket, that goes in between these before the wheel bolts are pressed in. What purpose would this serve?
Somebody somewhere (back in time) decided it needed this gasket.
Mike
Mike
1951 3100 5 window
kades51 #1157350 03/29/2016 12:59 AM
Keeps them from rusting together.
If you study the path of oil/grease from a leaky seal on both the front and rear hubs, you will see that the gaskets are to prevent oil/grease from wicking out to the brake shoes.
My Blog
