0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
On my 47 COE, the radiator filler is cracked. I think it's brass and I don't know how to repair it. Can you braze it with a torch and brass rod?
https://goo.gl/photos/7xrKhZNps6WyKdN36
https://goo.gl/photos/z1CZj1g6mp8yPL5QA
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
Crusing in the Passing Lane
Use solder, brass rod is too close to melting point of brass radiator, especially in cramped location. New brass filler necks are available.
Ed
It's unlikely you'll be able to repair a crack by simply soldering. Make a patch from thick shim stock and clean the area around the crack down to bright metal, then solder the patch over the crack. I'd also opt for a replacement if possible.
I agree with Jerry.
If you had the part off it could also be repaired with silver solder, then soft solder it back on. As another option.
•1952 Chevrolet 3800 pickup
---All pictures---
Is there a special method to clean it? I tried some brasso, but it didn't seem to do very well. I also tried a wire brush wheel and that was not much better.
If I did a patch, would the shim stock need to be brass Also?
1962 IH Scout 80
Sand paper is a good way to clean it. You'll also need flux for soldering, the liquid acid in a bottle and a little brush or corner of a rag works well for this.
I'd use copper or brass for the patch, cleaned the same way.
For heat if you haven't soldered anything like this I wouldn't recommend the torch. Instead a large electric soldering iron will make for an easier job. It's all about cleanliness and heat management. Too much heat is a very easy mistake to make. Use just enough for the solder to flow and only a tad more, anything further is counter productive.
---All pictures---
I haven't studied my 41 COE closely yet, but can you get the radiator out and take it to a shop? I did this in my 46 when I first got it. They cleaned it and repaired a few cracks. I'm still running it and have no problems with overheating!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
The truck is completely apart. This part is not attached to the radiator, it has a short hose to connect it to the radiator. My second link in my first post shows the whole part, unless the links don't work...
1962 IH Scout 80
File that one down to bright metal along the crack and clamp it into a vise to close it up. Then use silver solder to put a layer of repair material over it maybe 1/16" thick or more. It might be necessary to also run the silver solder all the way around the joint where the pressed-on top ring attaches. If it's soft-soldered the heat of applying the silver will cause it to leak or separate.
Stephen, I guess I should have looked at the photo's... It does appear to be brass. Mail it to me and I will tig weld it for you and send it back.
Randy Domeck
[email protected]
317-258-0039
Really Randy? I can do that.
1962 IH Scout 80
Use acid core solder or separate cleaner.
Ed
Stephen, May address is listed below. Let me know when it is on the way and I'll look for it. Glad to help out.
Randy Domeck
[email protected]
317-258-0039
Randy, that's a generous offer thumbs_up
Please share some pictures of the process/repair.
I've TIG welded brass a little and while it worked out OK it was not as easy as copper or most other metals because of the zinc.
Not having full confidence in by brass welding ability I'd be inclined to make a silver solder repair.
Grigg
---All pictures---
Stovebolters helping Stovebolters. Its just awesome and good on you Randy. I also thank you.
We do a lot of bronze work and a fair amount of brass... As well as titanium and a bunch of other materials that most people don't like to touch.
Send it along and I will be glad to help out.
Randy Domeck
[email protected]
317-258-0039
Randy,
I sent you a PM...
1962 IH Scout 80
For reference, this probably took 2-3 hours. Once the crack was repaired, we noticed that the top was also cracked in two places. The second we heated that up to weld, it came unsoldered, so it was removed. We repaired that and used silver solder to put it back on. And that led to the steel bracket coming unsoldered.... So we removed, cleaned and resoldered it as well.
See pictures here http://s1006.photobucket.com/user/rrdomeck/library/COE%20filler%20neck?sort=3&page=1
Randy Domeck
[email protected]
317-258-0039
Thanks for the pictures, nice repair.
These "little" projects are so often more time consuming or difficult than expected.
Grigg
---All pictures---
