3 members (1955 1 Series, DadsFirstPickup, Gdads51), 52 guests, and 3 robots.
Topics128,089
Posts1,056,364
Members48,442
Its my understanding that a Black tag on a generator is the 12V while a Red tag is a 6V. Is this correct.
I have one that is Black tag and has stamped on the tag
No. 72U (then a space and then the letter C stamped in with the word code out beside it like this:
No.72U---C code
You have it backwards, Alvin
black = 6v
red = 12v
Red tags are 12 volt units. I just checked out my stash, and I've got four generators with black tags- - - -all of them are from 6V vehicles and they all have straight housings and spring bands. One I cross-referenced had a part number 11102749- - - -1948-54 Olds, Buick, Pontiac and Chevy.
Thanks for straightening me out. I can now help a bolter in need.
I would like to add some more info for kicks.....Your two basic Delco tags that were used in the 40s through the early 60s Chevys were black 6 volt red 12 volt just as mentioned above. The same black tag that was used on the 6 volt starters and generators was also the same black tag used on the Distributors regardless of 6 or 12 volt applications.
Also, your 72U number is a Delco reman number and those tags were completely different in design. 72U was the reman number issued to 1102744 generator that was your basic late 40s early 50s 6 volt 30 amp generator.
Ken
That is very cool....I have never seen an experimental tag before. Typically when they start listing out Volts, Amps, series etc. they were on larger commercial type units.
