3 members (TUTS 59, WICruiser, 1 invisible),
125
Mod | | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its my understanding that a Black tag on a generator is the 12V while a Red tag is a 6V. Is this correct.
I have one that is Black tag and has stamped on the tag No. 72U (then a space and then the letter C stamped in with the word code out beside it like this: No.72U---C code
Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You have it backwards, Alvin black = 6v red = 12v | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Red tags are 12 volt units. I just checked out my stash, and I've got four generators with black tags- - - -all of them are from 6V vehicles and they all have straight housings and spring bands. One I cross-referenced had a part number 11102749- - - -1948-54 Olds, Buick, Pontiac and Chevy. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks for straightening me out. I can now help a bolter in need. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | I would like to add some more info for kicks.....Your two basic Delco tags that were used in the 40s through the early 60s Chevys were black 6 volt red 12 volt just as mentioned above. The same black tag that was used on the 6 volt starters and generators was also the same black tag used on the Distributors regardless of 6 or 12 volt applications. Also, your 72U number is a Delco reman number and those tags were completely different in design. 72U was the reman number issued to 1102744 generator that was your basic late 40s early 50s 6 volt 30 amp generator. Ken | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | That is very cool....I have never seen an experimental tag before. Typically when they start listing out Volts, Amps, series etc. they were on larger commercial type units. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | |
