3 members (Bill Marlow, tclederman, 52Carl), 54 guests, and 3 robots.
Topics128,090
Posts1,056,028
Members48,432
#115322 01/16/2002 4:12 PM
No response in the lounge so I will try here. Can anyone tell me if there is one or two seals for the windshield of my 38 panel delivery. The windshield now has a flat rubber gasket sandwiched between the frame and moves out with the glass. Is there another gasket or seal on the cab window frame?
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
#115323 01/16/2002 8:22 PM
I think your panel is the same as my 37 truck. It has just one seal. It has a lip that snaps in the frame and about a 1" lip that seals to the cab area. It goes around the windshield frame. The glass is set in tape in the frame. As you open the windsield the seal moves to. You can buy new seal for $20 or less. From what I have read here, they don't seal real good. You may have to add some type of foam seal to the inside of sealing area. Joe
#115324 01/17/2002 4:39 AM
Thanks, it's hard to find info on some of these things. Some of it is for pickups and some for cars but not much on the panel deliverys
