Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (Jon G, JW51, kades51, baldeagle, 68ironhead, Stovebolt48, GMCJammer51, dt235sd, 1 invisible), 55 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#1152842 03/01/2016 3:18 PM
jimbo 24 #1152845 03/01/2016 3:51 PM
Sorry but I can't see anything in any detail behind the Yuuge ad that covers the screen when I try to view photos at that place...
Give me ambiguity
or give me something else
jimbo 24 #1152890 03/01/2016 9:43 PM
What are you working on?
jimbo 24 #1152930 03/02/2016 2:04 AM
door channel i took out old channel and it was metal with tabs on it. i bought new channel from chevy parts and it don't fit inside old metal channel. if u click on the pic, it should show u
jimbo 24 #1152936 03/02/2016 2:45 AM
The new channel is not supposed to fit in that old metal channel. It replaces that old piece.
The old channel is missing all of the "felt" which use to be in it.
The new channel does not come with the metal tabs.
Carl
jimbo 24 #1152982 03/02/2016 5:39 AM
Former BMW Rider
Former BMW Rider
jimbo 24,
52Carl nailed it for you. The new channel is secured with an adhesive around the top of the window opening and most likely a front and rear channel retainer (lower glass run posts) that the new channel clips into, at least that's how it's installed on the 3100.
Check out this thread as Brad Allen has some good pics of the channel retainers.
Good luck,
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
jimbo 24 #1153153 03/03/2016 3:48 AM
ok carl, i got u. i was hoping i coulsd put it in old channel because it just clips on edges. so much easier than putting weather strip adhevsive
jimbo 24 #1153825 03/07/2016 2:03 AM
last ? does the new channel go in with weather strip adhesive or glue
jimbo 24 #1153987 03/08/2016 12:57 AM
Former BMW Rider
Former BMW Rider
jimbo 24,
I've seen threads that refer to weather strip adhesive and glue. This link to JC refers to glue. It appears the PO of my truck used weather strip adhesive and it seems to hold just fine.
Let's see what others have to say.....good luck!
Andy
jimbo 24 #1154274 03/09/2016 8:50 PM
anyone
jimbo 24 #1154281 03/09/2016 9:53 PM
Former BMW Rider
Former BMW Rider
Here's a link to a thread in the Doors sub-forum that speaks to the use of small screws.....
Andy
jimbo 24 #1154308 03/10/2016 1:52 AM
I'm doing the doors in the 48 2 ton right now, and plan to use the tiny screws that the original had to hold in the upper window frame. Maybe a bead adhesive in the corners and the lower tracks.
jimbo 24 #1154325 03/10/2016 2:47 AM
i am going to try adhesive
jimbo 24 #1154341 03/10/2016 4:01 AM
Former BMW Rider
Former BMW Rider
Jim Sears and jimbo 24,
Please report back on how the installation of your window channel projects turn out. Others will benefit from your experience and expertise.
Good luck,
Andy
jimbo 24 #1154645 03/12/2016 3:50 AM
ok i will do that i am still working on it
jimbo 24 #1157710 03/31/2016 1:27 AM
[IMG]http://i1296.photobucket.com/albums/ag3/cuz2424/Chevy/IMAG0286_zps2vwxi2g8.jpg[/IMG][IMG]http://i1296.photobucket.com/albums/ag3/cuz2424/Chevy/IMAG0287_zps8xhngfgw.jpg[/IMG][IMG]http://i1296.photobucket.com/albums/ag3/cuz2424/Chevy/IMAG0289_zpsp6t1txoz.jpg[/IMG] the last pic is of screw that was in the way on channel. it holds the vent shade, so i put channel in and then put screw in. remember, i am no expert, this is how i did it. also the vent window has 3 screws and 2 bolts in door. and i glued the channel and put clamps to hold it down hope this helps someone
