0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Sorry but I can't see anything in any detail behind the Yuuge ad that covers the screen when I try to view photos at that place...
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | door channel i took out old channel and it was metal with tabs on it. i bought new channel from chevy parts and it don't fit inside old metal channel. if u click on the pic, it should show u | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | The new channel is not supposed to fit in that old metal channel. It replaces that old piece. The old channel is missing all of the "felt" which use to be in it. The new channel does not come with the metal tabs. Carl
| | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | jimbo 24, 52Carl nailed it for you. The new channel is secured with an adhesive around the top of the window opening and most likely a front and rear channel retainer (lower glass run posts) that the new channel clips into, at least that's how it's installed on the 3100. Check out this thread as Brad Allen has some good pics of the channel retainers. Good luck, | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | ok carl, i got u. i was hoping i coulsd put it in old channel because it just clips on edges. so much easier than putting weather strip adhevsive | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | last ? does the new channel go in with weather strip adhesive or glue | | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | jimbo 24, I've seen threads that refer to weather strip adhesive and glue. This link to JC refers to glue. It appears the PO of my truck used weather strip adhesive and it seems to hold just fine. Let's see what others have to say.....good luck! | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | Here's a link to a thread in the Doors sub-forum that speaks to the use of small screws..... | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I'm doing the doors in the 48 2 ton right now, and plan to use the tiny screws that the original had to hold in the upper window frame. Maybe a bead adhesive in the corners and the lower tracks. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | i am going to try adhesive | | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | Jim Sears and jimbo 24,
Please report back on how the installation of your window channel projects turn out. Others will benefit from your experience and expertise.
Good luck, | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | ok i will do that i am still working on it | | |
