8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#1151475 02/22/2016 5:59 AM
OK so I'm getting ready to rewire my truck, due to many breaking their insulation. Had been going to do from scratch,but found this harness:
classic parts harness
Truck was previously converted to 12v, appears to be lights and all. Anybody tried a basic harness like this? Decent deal?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1151486 02/22/2016 11:33 AM
I used the generator version for my frame-off 1950 which was completed in 2011, I have had zero problems with it. Fairly easy to install and comes with turn signal wiring. I heat shrinked all the connections, carefully ran and supported everything and it has been a good harness. I converted my truck to 12-volts with the installation of this harness.
https://www.flickr.com/photos/advance-design_parts_co/8129206782/in/album-72157631867396207/
52vff #1151488 02/22/2016 12:37 PM
If you need no more than original circuits and add-on turn signals, you will not find a better quality harness at a better price (except maybe Jim Carter's "standard harness" - about the same quality at about the same price).
I have used the Classic Parts harness on two "restorations".
NOTE: the lengths of some leads might be a little short on a 2-ton truck. Maybe someone will comment about the length of the front fenders?
