| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | OK so I'm getting ready to rewire my truck, due to many breaking their insulation. Had been going to do from scratch,but found this harness: classic parts harness Truck was previously converted to 12v, appears to be lights and all. Anybody tried a basic harness like this? Decent deal? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used the generator version for my frame-off 1950 which was completed in 2011, I have had zero problems with it. Fairly easy to install and comes with turn signal wiring. I heat shrinked all the connections, carefully ran and supported everything and it has been a good harness. I converted my truck to 12-volts with the installation of this harness. https://www.flickr.com/photos/advance-design_parts_co/8129206782/in/album-72157631867396207/ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you need no more than original circuits and add-on turn signals, you will not find a better quality harness at a better price (except maybe Jim Carter's "standard harness" - about the same quality at about the same price).
I have used the Classic Parts harness on two "restorations".
NOTE: the lengths of some leads might be a little short on a 2-ton truck. Maybe someone will comment about the length of the front fenders?
