| | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Lets just say I"m ignorant when it comes to body work. I've watched the bondo tape a few times but don't think I learned to much! My question is why use expoxy? I guess I'm saying this because I'm planning on trying to do some work myself. I figure using a spray can of Rust-Oleum would work fine since I will be using it only temporarily and it will be sanded back off to "find" all the blemishes?! Then reprime and paint. I'm sure ya'll are going to set me straight here so lets have it....MartinSr? and the rest of you!  | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Very simple. Only epoxy primer will SEAL and PROTECT the metal from rust until the final paint job. 1. Sand to bare metal. 2. Epoxy prime within 24 hours. 3. Do body work. 4. Prime and blocksand. 5. Paint.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | i am another novice: what is the difference between epoxy primer and por-15 in terms of protecting a frame for example. thanks | | |
