0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Got looking while i was rebuilding the door hardware, how the heck am i going to lock it? What are you 39-46 guys using for door locks? | | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | My '40 drivers side locks from the inside and the passenger side has a key. I have an extra keyed lock that I am going to have keyed to match for the drivers side.
Brian D
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | 49 brian, Is that the lock used on the lower part of the door? Ive seen one before but figured it was just something someone came up with. Do they make reproductions? Maybe it could be moved to just below the door handle. hmmmmm | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | two of those would be cool, but it doesnt look like mine. Where is the square rod that goes from the handle to the latch mechanism. Also where would you get the lock cylinders? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Your passenger side door handle should look like that one. Cylinders show up on ebay and can be rekeyed. I think the car lock cylinders are the same as truck. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | nope, mine is the same as on the drivers side, no lock | | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | As far as the key lock I think 41 and later had key lock below door handle not in the door handle. That is how mine was. But I have read that 1941 can also have the key in the door handle so maybe they switched mid year but your 39 should have it in the handle on the passenger side. All of them were passenger side exterior lock only with a little interior knob at the rear of the driver's door. I asked about this once before and someone told me that everyone exited the passenger side in the city (where you actually used locks) because the streets were so narrow. Sounds good anyway. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | mine has non locking handles on both sides, the latch mechanism has the little wing to lock that door but it doesnt work. on the passenger side it had what looks to me like a cabinet lock down low on the door. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | they are in the door handle through 39 if my source is correct.(not positive though) My 37 is the same way. no door lock on driver side but one on the passenger. BUT some didn't have outside locks at all. I sold my spares but seems I saw a door lock handle in the ads of VCCA magazine. | | | | | Joined: Jun 2001 Posts: 37 Junior Member | | Junior Member Joined: Jun 2001 Posts: 37 | This took a lot of work, but I took an original passenger door lock cyl, turned it over and installed in drivers door. You have to find another passenger locking latch mech, to take apart to use the locking links, which have to be cut and flipped,welded ,and install in the drivers latch assembly. It took a little time, but it looks original, key on drivers door goes in upside-down, but works great. Both doors have same lock under handle. Just can't unlock or lock from inside. It was an idea that worked for me.
"Boop-Boop-a-doop"
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Thanks Rayman Another alternative. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Is there other years I could be looking for that will work? Also do any of the cars have compatable door handles? | | |
