0 members (),
133
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | What was the original color of the headliner of a 1950 3100? Did the sun visor match? Did the armrest come standard or did you have to pay extra? Thanks for any correct info. | | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | Thanks for the quick reply. I'm going to order the correct red seat and door panels but the project didn't come with the old headliner to figure out the color. It's going to be a very colorful 3100! | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | The headliner I bought from bowtiebits.com was the best of the three that I bought from other vendors and it appears to be a pretty good match (for cardboard). | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | blue69,
Are you referring to correct red as in red-red or burgundy/maroon red?
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | It is probably not what you are looking for as it is mostly brown with a very slight reddish tinge to it. The fit was more important to me after trying a couple of others and reading the other posts regarding poor fit.
| | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | I'm wanting the truck to look like it came from the factory. I'm confident I have the paint right but am having trouble figuring out the cardboard headliner and sun visor. I have one original door panel and it looks maroon with black in the recessed grain. I bought the brown seat and door panels but they don't look right so I'll send them back and try to make it correct. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Here's a shot of my '52 GMC door panels that are covered with fabric from SMS. door panel The backer is ABS plastic. None of the reproduction door panels come close to matching the original embossed grain pattern and color. I used this same SMS fabric to cover the seat and I think it comes much closer to matching the original fabric than the pre-stitched seat cover from Jim Carter. Mike | | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | Huck, your truck looks fabulous! You did a great job of matching the original look, do you remember the SMS color? | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | It's called "Old Truck" scroll down to the bottom of the page and you will see it there. old truck | | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | Thanks Huck, I will order some today. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the link Huck, fabric looks great. Who did your stitching on the seat covers?
dg
Denny G Sandwich, IL
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Denny I had a local upholstery shop stitch them and using your photos as a guide, had the same shop cover the springs with burlap, coir and the seat covers using the original barrel clips. The seats are firm but comfortable. Mike | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | They turned out really nice. Sounds like you used about the same build up they did originally. I've found that to be quite comfortable and as you say, firm as opposed to the foam most of the upholsterers are using. tks dg
