1 members (walter74), 78 guests, and 2 robots.
Topics128,096
Posts1,056,477
Members48,444
#1142441 01/02/2016 1:05 AM
Hi,
New to forum, my first post actually.
I have a 49 Chevy 3600 long bed, that my wife's grandfather purchased new, that's 67 years in the family. I have a 59, 235 to put in it but she wants a V8, so a V8 it is.
Looking to do this with the stock steering and suspension, so the steering box stays. I would like to avoid the pitfalls that I might encounter with this swap. What are the best front mounts? Haven't decided on trans yet, but probably a t/h350. Exhaust manifolds or headers? Been a while since I did a engine swap but I remember lots of problems arise.Can you point me in the right direction? Thanks.
Maybe this page will help a little. Jbennett
Ex Hall Monitor
Ex Hall Monitor
A word of caution. If you're going to make it go fast be sure to make it whoa fast as well. Pay attention to (modernize) the brakes.
You do not, repeat, DO NOT have to re-locate the steering box. Just use a 55 or 56 car 265 V8 left hand exhaust manifold. Do a search for "offset engine" and in the name box put "kahoys". He did a very sanitary install with a good description and pictures. You can get a V8 mount set up from Chassis Engineering if you don't want to fab your own.
Evan
I like the mounts from Chassis Engineering as seen here. Bolt in or weld in. I also keep my 1/2 ton front axle.
I'd also recommend a 700R4 rather than a 350 if you can get your hands on one....or some other like a 400. The 350 tranny doesn't have OD so rpms will be higher...or you'll need a higher rear ring and pinion ..... and on and on and on.
The guys in Hi Po Forum can help you a lot on this one.
