BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,295 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2015 Posts: 6 New Guy | New Guy Joined: Sep 2015 Posts: 6 | Hi, New to forum, my first post actually. I have a 49 Chevy 3600 long bed, that my wife's grandfather purchased new, that's 67 years in the family. I have a 59, 235 to put in it but she wants a V8, so a V8 it is. Looking to do this with the stock steering and suspension, so the steering box stays. I would like to avoid the pitfalls that I might encounter with this swap. What are the best front mounts? Haven't decided on trans yet, but probably a t/h350. Exhaust manifolds or headers? Been a while since I did a engine swap but I remember lots of problems arise.Can you point me in the right direction? Thanks. | | | | Joined: Oct 2000 Posts: 112 Shop Shark | Shop Shark Joined: Oct 2000 Posts: 112 | Maybe this page will help a little. Jbennett | | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | A word of caution. If you're going to make it go fast be sure to make it whoa fast as well. Pay attention to (modernize) the brakes.
| | | | Joined: Apr 2005 Posts: 2,832 'Bolter | 'Bolter Joined: Apr 2005 Posts: 2,832 | You do not, repeat, DO NOT have to re-locate the steering box. Just use a 55 or 56 car 265 V8 left hand exhaust manifold. Do a search for "offset engine" and in the name box put "kahoys". He did a very sanitary install with a good description and pictures. You can get a V8 mount set up from Chassis Engineering if you don't want to fab your own.
Evan
| | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I like the mounts from Chassis Engineering as seen here. Bolt in or weld in. I also keep my 1/2 ton front axle. I'd also recommend a 700R4 rather than a 350 if you can get your hands on one....or some other like a 400. The 350 tranny doesn't have OD so rpms will be higher...or you'll need a higher rear ring and pinion ..... and on and on and on.
The guys in Hi Po Forum can help you a lot on this one. | | |
