0 members (),
89
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Took my seat for the 53 in to an upholstery shop and the owner is telling me that the c-clips from jim carter are to small and wont go over the material and frame is that possible? I know several of you have used these.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you mean the hog rings, any auto upholstery shop should have a stock of different sizes on the shelf for different materials and assembly techniques, if it's a furniture upholstery shop accustomed to using tacks into wood frames, ask'em to check their supplier
Bill | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | No, I mean the c-clips that go over the material and the seat frame so you don't have to use hog rings and they do not tear the material. The only example that I saw was on Denny Graham site showing his seat being recovered. Thanks | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The shop I use showed me three thickness of material that could be used for my seat. There is no way the stock clips would fit over the two thicker materials. My seat actually had a thick (but cheap) recover over the original and had much thicker clips. I saved both when I stripped the seats. The shop I use said they had plenty of new ones and didn't want them.
Chuck | | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Chuck, Thanks for the info. I will call J Carter tomorrow and ask about the size of the clips.
thnx | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chuck's theory sounds good.
I used JC's clips with JCs upholstery set on the seats in my Suburban. They worked fine.
| | | | | Joined: Feb 2010 Posts: 45 New Guy | | New Guy Joined: Feb 2010 Posts: 45 | Chuck could you please direct me to where I can get bigger clips,I didn't use the j carter seat cover and I guess the material is too thick.Or does anyone have any Ideas as to where I could locate different size c-clips?
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | my seat (51 chevy) the original clips were inside the channel that runs around bottom of the seat.The vinal was wrapped over the channel and the clips were pushed into the channel to hold the material. when I redid the seat I put it back together the same way using a putty knife to push the clips into the channel. Check out my post here in interiors seat is done
| | | | | Joined: Apr 2014 Posts: 22 New Guy | | New Guy Joined: Apr 2014 Posts: 22 | eric( elm (51 Basket case)), did you happen to know the name of the clips of the clips you used? Ive been looking everywhere for them and cannot find them. I broke about 20-30% of them taking them out. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The "barrel" clips that we originally used on these seats worked fine and lasted 60+ years. And the original material was a very heavy gauge Naugahyde. It's tough but the clips will press over this thickness and like your socks do to your ankles, will eventually press deeply into the material leaving an impression in it. The reproduction clips "look" the same as the original ones but they are not heat treated correctly. Many of them are to hard and in stead of acting like a spring, they snap when you try to press them on. And some are to soft and don't put enough tension on the material. I find that even after nearly a decade, they still haven't left an impression on the upholstery material that JC used. I mixed them with as many of the original clips as I could save and those original ones do hold well. There is nothing wrong with Hog Rings, they've been used in upholstery since the beginning of time. Unfortunately they can't be used with the flange that the GM seats wire made with. Denny Graham Sandwich, IL
Denny G Sandwich, IL
