| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 10 New Guy | | New Guy Joined: Oct 2015 Posts: 10 | Is there a way to find members in my area | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome to the site. There is a map somewhere that you can put your handle and location on, but it's hard to find and not everyone uses it. I do remember one or two members from up your way, not sure how close to Winnipeg. Maybe Tiny or someone else can direct you to the map. Leo edit, if you go to the site search box on the left and type in 'where in the world...' the map should appear.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and the another way is to post regularly with your questions so others from your areas can see YOU. I will also add that you may want to post in the forum of B.C. bolters. A lot of Canadians check in there.......and of coarse lots of people see whats going in the Greasy Spoon forum.
Welcome, 50Chevy1 Ton and good luck on your project. Guys here are excellent about helping out. | | | | | Joined: Oct 2015 Posts: 10 New Guy | | New Guy Joined: Oct 2015 Posts: 10 | Thanks for the replys, just happy to be part of the community. | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Welcome to the bolt. I'm a couple of provinces to the west of you with quite a few fellow bolters in between. Doyle | | |
