5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1140672 12/22/2015 6:46 PM
Is there a way to find members in my area
Leo Offline
Moderator
Moderator
Welcome to the site. There is a map somewhere that you can put your handle and location on, but it's hard to find and not everyone uses it. I do remember one or two members from up your way, not sure how close to Winnipeg. Maybe Tiny or someone else can direct you to the map.
Leo
edit, if you go to the site search box on the left and type in 'where in the world...' the map should appear.
...and the another way is to post regularly with your questions so others from your areas can see YOU. I will also add that you may want to post in the forum of B.C. bolters. A lot of Canadians check in there.......and of coarse lots of people see whats going in the Greasy Spoon forum.
Welcome, 50Chevy1 Ton and good luck on your project. Guys here are excellent about helping out.
Thanks for the replys, just happy to be part of the community.
Welcome to the bolt. I'm a couple of provinces to the west of you with quite a few fellow bolters in between.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
