2 members (Otto Skorzeny, 1 invisible),
131
Mod | | | Forums66 Topics128,086 Posts1,056,334 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I've been known to do things in the wrong sequence so let me ask which works best. I have the windshield frames primed and was going to wait until after the color coat but now I'm wondering if that is best. This is for my '40. Operators standing by.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I did my windshield after paint on the panel but I have a wide rubber gasket to help hide a mistake.
....is the 40 a two piece windshield? If so, I'd say paint and be verrrry careful from there on. Just my .02 | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | I can't think of a single thing that you'd install before painting. There's always an exception, but I can't see one here.
You might want to err on the side of caution, and wait. There's no harm in putting it in after paint... or is there?
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Yes, the '40 is 2 piece. I am leaning to painting it first but curious what others have done.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I would follow the factories' lead and install afterwards. You can always tell a paint job that was done after the fact from the masking - no matter good - that reveals it was not original. Even in modern assembly lines the glass is always installed after the paint. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Isn't the whole purpose of the paint is to act as a moisture barrier for the metal? So without paint between the rubber and metal won't that increase the odds of rust?
Paint and then the glass - no question about it.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I painted my 39 windshield frame back in 1977, then installed the glass. Still looks good. Did not use a rubber gasket to install. Did it the old way using black window tape material, that was how the original window was installed. No rust, no leaks after all these years.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | OK, paint first it is. Thanks youz guyz
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I had frames painted first. Had a glass shop install glass using polyeurethane caulking. Exterior of frame has a Steeles Rubber gasket that slides into the perimeter slot to seal against body opening. Also purchased a new vertical stainless steel center bar complete with rubber gasket factory installed. | | |
