3 members (rfs56trk, Gdads51, jmoore), 113 guests, and 4 robots.
Topics128,087
Posts1,056,375
Members48,442
I've been known to do things in the wrong sequence so let me ask which works best. I have the windshield frames primed and was going to wait until after the color coat but now I'm wondering if that is best. This is for my '40. Operators standing by.
Dennis
40 Chevy 1/2 ton
I did my windshield after paint on the panel but I have a wide rubber gasket to help hide a mistake.
....is the 40 a two piece windshield? If so, I'd say paint and be verrrry careful from there on. Just my .02
I can't think of a single thing that you'd install before painting.
There's always an exception, but I can't see one here.
You might want to err on the side of caution, and wait. There's no harm in putting it in after paint... or is there?
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Yes, the '40 is 2 piece. I am leaning to painting it first but curious what others have done.
Dennis
40 Chevy 1/2 ton
I would follow the factories' lead and install afterwards.
You can always tell a paint job that was done after the fact from the masking - no matter good - that reveals it was not original.
Even in modern assembly lines the glass is always installed after the paint.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
Isn't the whole purpose of the paint is to act as a moisture barrier for the metal? So without paint between the rubber and metal won't that increase the odds of rust?
Paint and then the glass - no question about it.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I painted my 39 windshield frame back in 1977, then installed the glass. Still looks good. Did not use a rubber gasket to install. Did it the old way using black window tape material, that was how the original window was installed. No rust, no leaks after all these years.
Rick
1939 Chevrolet Stake Truck
OK, paint first it is. Thanks youz guyz
Dennis
40 Chevy 1/2 ton
I had frames painted first. Had a glass shop install glass using polyeurethane caulking. Exterior of frame has a Steeles Rubber gasket that slides into the perimeter slot to seal against body opening. Also purchased a new vertical stainless steel center bar complete with rubber gasket factory installed.
1940 Chevy KC 1/2-Ton
