4 members (Otto Skorzeny, SNOYL, Wayne67vert, Barry Martak), 101 guests, and 3 robots.
Topics128,096
Posts1,056,482
Members48,444
#1136032 11/24/2015 6:10 AM
I have a 59 gmc 2 ton. It has 20" rims and I cant figure out which type of rims it has. Ive looked in the tech tips and read Griggs post about different rims but I cant determine what these are. None of the rims in the tech tips appear to have this two inch ring aroud the outer part of the rim. Here are pics of the front, rear and the inside of the front rim. I dont have any pics of the rims with the tires dismounted. I havent touched the wheels since I got the truck (two weeks ago) in fear of not knowing what rims these are and how dangerous these rims can be. I know that the rh5's are the widow makers and are dangerous but what about other types. Specifically
these. Thanks
[IMG]http://i1380.photobucket.com/a...14_135453_zpsamvgyrz5.jpg~original[/IMG]
[IMG]http://i1380.photobucket.com/a...14_135515_zpscgycl3lq.jpg~original[/IMG]
[IMG]http://i1380.photobucket.com/a...14_135737_zpsbkbckuji.jpg~original[/IMG]
They look like 6 hole stud piloted R-H5° which were very common in those days.
bcgmc #1136037 11/24/2015 10:08 AM
Hello bcgmc,
I think those are the true "widow makers" R-H5
A must read here - http://www.stovebolt.com/techtips/wheels/
1947.2 Chevy 2-Ton 161". Motor- 1962 235cid
bcgmc #1136043 11/24/2015 12:08 PM
New guy,
Unfortunately they are definitely the Firestone RH5's. My trucks use the same 6 lug Budd pattern as yours. I have found that this lug pattern was used on many Ford, Dodge, IHC, GMC 2 ton trucks and buses from the 1940's to 70's. Widen your search and you should be able to find some safer split rims. Find your nearest old timey junk yard and look at the old school buses that the owner uses for dry storage...those buses are often great donors.
Others have mentioned the 22 inch tubeless rims, but I have had more luck hunting unicorns.
Lots more pictures
Thanks for the bad news guys lol. Paul that unicorn is an elusive animal. I think I will be swapping the rear to an 8 lug and I will do griggs p30 swap on the front.
22.5" 6 lug Budd wheels are not "Unicorns" in my experience. If you want them you can find them, I have bought and sold a few sets myself.
I'd think hard about swapping an 8 lug (on 6.5"?) rear axle under a big truck. Might want something rated close to the original axle.
•1952 Chevrolet 3800 pickup
---All pictures---
Those same school busses also had 22.5" rims which are the direct replacement for your 20" wheels...keep looking, they are out there.
A 10.00 x 22.5 is the exact replacement for your 9.00 x 20's.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I am going to replace the suspension with a 1 ton suspension as well. Not just do an 8 lug on the 2 ton springs. I have no need for 2 ton suspension or 2 speed axle. I'm turning my 2 ton into a 1 ton. Would that be ok? Im going to do the p30 swap in the front.
It's your truck, your call. Just try to think about what you want from the truck and keep that in mind as you go along so you get there in the end.
My opinion; big trucks/big fenders with little tires look odd. If that might also look odd to you then mock it up with the new tire size in the fender first and see how it suits you.
---All pictures---
I think that's why he was looking for smaller fenders in one of his other posts.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
bcgmc #1136491 11/26/2015 11:20 PM
Crusing in the Passing Lane
There are D-60's out there w/ that bolt pattern(6) w/ matching front axles(22.5")look for airport buses, school buses ambulances. 16, 19.5" tires look undernourished w/ 20" fenders
Like Grigg says.
I've decided to keep my big fenders and wheels. I'm trtying to find wheels. Can someone clear something up for me? Reading the tech tip about wheels there is alot mentioned about 10 lug 7.25 pattern. I know this may be a dumb question but will these fit my 6 lug pattern?
No they will not.
But you're in a better situation with your more common and widely used 6 lug Budd wheels. 22.5" tubeless wheels were available and can still be found on all sorts of vehicles and makes.
---All pictures---
The rims you are looking for are about 6-3/4" wide between the tire bead flanges. These rims were available 8-1/2" wide, but that's to wide for your truck...
Tire size will more than likely be 10.00 x 22.5" (exact replacement for 9.00 x 20").
Happy Hunting!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Moderated
Moderated
bcgmc I have....
Hi,"blowin smoke",and Welcome! I'd send you a P.M.,but you're still moderated,so I have to put this in plain view! I'm grateful,that you have rims available,and are willing to help a guy out,but,PLEASE Follow the "Bolt" Guidelines! If you have parts for sale,PLEASE post in the "Classifieds" section. This'll keep you out of trouble! PLEASE read the "Guidelines",in the "Welcome" section! THANKS!!
Mo' Tater
