| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Here I go again needing help. I put a 283 in my 66 C10 and it has the short water pump on it. I bought aluminum brackets for the power steering and I would like to do the same for the alternator. The crazy thing is is I can't find a bracket unless I have the long water pump. But I don't know the difference or will the long one go on my 283 or do I want a long one at all. It would put the fan closer to the radiator if that matters. Got any advise.
Thanks Rocky | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | to me the fan, close to the radiator, is a good thing and some folks have to use a fan spacer to get the fan close...as within a half inch. You should have plenty of room and if you have a heating/hot problem the closer to the radiator and a fan shroud would be a good thing. I doubt a hot problem in Utah! | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Have you tried http://www.alangrovecomponents.com/?Not sure they do aluminum though... but they do make excellent, simple brackets. As for the fan being close to the radiator.. as long as you have a correct shroud that won't be an issue. Hope that helps. _____ John
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there is a relationship between the shroud and the fan to be efficient. the fan should sit right in the opening of the shroud, not inside of it. if you are running stock exhaust manifolds that is where the alt should mount on the s/pump. with headers there are mounts that attach to the frt exhaust flange outlet. jegs or summit may have something. fan shouldn't be any closer than 3/4" ron | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | There was an article on a web site about pumps and if I change to the long pump I will have to buy new pulleys because they are different for each pump so I will stick with the short pump.
Thanks John for the link that bracket will work but I can't just by the one I need I have to buy two brackets but I will look around else were because that bracket will work just fine.
Hi Ron I am glade you mentioned the shroud I haven't been looking for one but I will get started. At least I know now what size to buy. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | climberman, have you thought about using the brackets off a V6 S-10 which you can use the brackets and go to a serpentine belt. Switch your water pump for a V6 pump (reverse) and your set to go. Saves money too.
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I would have never thought of all that achipmunk but now I have bought all of the pulleys and brackets for the Power steering. I went ahead and bought the bracket from the link John gave me they were really helpful. I sent them pictures of my motor and we decided that it was a fit. | | |
