2 members (Phak1, Bill Hanlon), 116 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#1134769 11/17/2015 6:17 PM
Can anyone steer me to a vendor who makes a modern cluster that fits into the dash of a 46 pickup? I have seen them but now can't seem to find them. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I've seen them on eBay. They only make them in 5 gauge, though. I wanted an in-dash tach so I enlarge the stock opening and made my own insert out of 18ga and welded it into the dash.
My 46 GMC on Photobucket
Chevs of the 40's carries a few 5 hole billet panels.
1940 Chevy KC 1/2-Ton
Yeah, I've seen the 5 hole billet and 2 hole (large hole) billet panels for purchase.
Check out Oldnewparts.com on EBay.
They have a lot of different types that should work and prices are reasonable.
dj durant
More pix on Flickr
I just found them, I was hoping to find one that had a tach and would still fit in the original opening. I have my dash already blasted and fiinished painted. Dave
1941 Chevy
Speedway might have "new" gauges to fit old holes.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
There's nothing that will fit 6 gauges in your stock opening (speedo, 5 smalls, and a tach). There just isn't enough room. The tach is the reason I had to enlarge my stock opening.
cm
Nobody sells a direct fit gauge set for these, just the billet inserts.
There are a few " Dual Gauge " units out there with Tach and Speedo on 1 face. Try Autometer or Speedhut.
Do the billet inserts fit properly in the existing hole in the dash? Dave
1941 Chevy
look at the dakota gauges. they will build a set to fit your dash with a life time waranty
Detroit (New Vintage USA) gauges makes a nice set. Fit std dash holes with stainless adapter ring perfectly.
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
I do not see anything for 46, only 47 and newer. Dave
1941 Chevy
