8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible),
77
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I don't have the proper fenders for the side mount spare, so I am looking to put the tire under the rear box.
1. Is this like the originals,and I'll be able to find them used, if I can slither under one of these junk yard trucks?
2. How do they attach, I've seen diagonals and straight, centered front to back ones on modern trucks.
3. Can you buy new?
55 1st Chev.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I know that somewhere I have run across an article on making a spare tire fender. I believe it was in the Tech tips section on this very site. Basically, they made a crdboard templat ant traced oval onto fender, cut it out and inverted removed piece and welded into place for proper concave section to clear spare. Don't know if it works but I read it in awe! | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Surely you have some type of underbed mounting bracket still in place ? Hopefully more will chime in as to typically how most 55's carried their spare. My '50 has a straight running bracket from front to back. This long bracket is riveted to a cross brace.
I would think though by carefully looking under the bed, there must be signs of how your spare was originally attached. No ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | '55.1 had a diagonal saddle with a pivot point on the forward (driver's side) end. Do a search on all forum for "spare tire carrier" and you'll get tons of info on both the early AD slide-out and the later drop racks.
Post an ad in the Swap Meet if yours is missing. I know MT has one, he got his @ss chewed for linking his ebay auction in the Lounge. :rolleyes: | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for the tips. I had a 70 chev truck and know roughly how it was, but wasn't sure what should have been on my 55.1. I have spent quite a bit of time under mine repairing and attaching the box, and I havent seen anything but suspicious holes where it might have been. Thanks again!
55 1st Chev.
| | | | | Joined: Jun 2000 Posts: 52 Member | | Member Joined: Jun 2000 Posts: 52 | Check the swap meet, I may have what you need. Feel free to call, 636-532-7576 be around Sunday from 10am till around 3pm. | | |
