10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible), 58 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
I don't have the proper fenders for the side mount spare, so I am looking to put the tire under the rear box.
1. Is this like the originals,and I'll be able to find them used, if I can slither under one of these junk yard trucks?
2. How do they attach, I've seen diagonals and straight, centered front to back ones on modern trucks.
3. Can you buy new?
55 1st Chev.
I know that somewhere I have run across an article on making a spare tire fender. I believe it was in the Tech tips section on this very site. Basically, they made a crdboard templat ant traced oval onto fender, cut it out and inverted removed piece and welded into place for proper concave section to clear spare. Don't know if it works but I read it in awe!
Shoulda looked and found it before I started post, but here you go. Side mount fender mod courtesy of stovebolt. com tech tips
C Online: Content
Surely you have some type of underbed mounting bracket still in place ? Hopefully more will chime in as to typically how most 55's carried their spare. My '50 has a straight running bracket from front to back. This long bracket is riveted to a cross brace.
I would think though by carefully looking under the bed, there must be signs of how your spare was originally attached. No ?
Craig
'55.1 had a diagonal saddle with a pivot point on the forward (driver's side) end. Do a search on all forum for "spare tire carrier" and you'll get tons of info on both the early AD slide-out and the later drop racks.
Post an ad in the Swap Meet if yours is missing. I know MT has one, he got his @ss chewed for linking his ebay auction in the Lounge. :rolleyes:
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
Thanks for the tips. I had a 70 chev truck and know roughly how it was, but wasn't sure what should have been on my 55.1. I have spent quite a bit of time under mine repairing and attaching the box, and I havent seen anything but suspicious holes where it might have been. Thanks again!
55 1st Chev.
Check the swap meet, I may have what you need. Feel free to call, 636-532-7576 be around Sunday from 10am till around 3pm.
