0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Hi, I have used this site for so much help, but I can't find anything on my current problem. 1949 1/2 ton with a '57 235. 12 volt 6volt starter I've had it running only with the choke on, and now it won't start or run. The starter has burned out so I replaced it, it turns over once then sounds like the battery dies, so I bought a new battery, but same thing. I've checked the valve gaps, I can spin it by hand with the plugs out, not sure what to do. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check you ground strap, if paint or rust of bad cable, you will get poor current flow if at all. BTW I've been using original 6 v starter for many years without a problem. Good luck | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Make sure you're getting fuel. If it only ran with the choke on, that makes me believe it was running very lean. Usually the mixture had to be richer on a cold start-up | | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Also, when I turn it over the starter is sparking and smoking. I took it back and they tested the starter and it's not the problem...or so they say. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know what your description "12v six volt starter" means. If you mean that you have a 6 volt starter with a key activated solenoid, and it is hooked up to 12 volts, I would think that could be a big problem. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | This could also be a problem with your Ring Gear not being the correct number of teeth for your replacement starter. That entire issue would be here: http://devestechnet.com/Home/FlywheelThe symptoms would be less than one revolution before it starts to bind up. | | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Well I am 100% positive it is a 6 volt ring gear. I'll have to check out the new starter and see how many teeth it has. | | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | And I have converted the truck to 12 volt but maintain the 6 volt floor stomp starter. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | qdub - I cannot imagine how a new or rebuilt stomp starter could have the wrong pinion gear but you might want to check that the gear does have the 9 Teeth - and you might want to check that the pinion gear diameter measures 1.187" and the pinion shaft should measure . 5625". Hope this helps, I just went through a similar problem on my 54'. The PO did the 12V conversion and installed an incorrect 12V car starter that also has 9 teeth, has a 1.000' diameter gear and a .4787 shaft....same number of teeth, but won't engage properly, get lots of noise and other nasty stuff.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | They do make 12v stompers. The tooth count on the starter side is the same as the 6v one, just pitched differently. Do what Dusty says and its possible they gave you the wrong animal. Good luck! | | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Went back and they gave me a different one. Works great. Now just re-do the carb, might be able to go for a drive soon. | | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Fantastic ! Drivin is a whole lot more fun than wrenching...
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | Deve You mentioned 12v stomp starters are available with same number of teeth as 6v starters. I have a 49-3100 with a 55-235 converted to 12v. I would be interested in getting one. Thanks Doug | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Just FYI, the tooth count on the starter(6 Volt and 12 Volt stomp starters) is the same. The tooth count on the flywheel is different. The tooth pitch(size) is what is different on the 6 Volt starter from the 12 Volt starter. The Shaft diameter is different as well. The Solenoid is different 6 Volt verses 12 Volt, for the starters used with the push button or key switch.
Steve H
