1 members (2-Ton),
87
Mod | | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | I have a chance to buy a 1990 XJ6 at a good price, does anyone know if this year Jag front and rear suspension will work on my 1955 Cameo?
No such thing as a horse too fast!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Such butchering can be done on a Cameo, but why? You have a somewhat rare truck. Why not restore it stock? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Such butchering can be done on a Cameo, but why? You have a somewhat rare truck. Why not restore it stock? 1. You don't know the condition of the Cameo (maybe it's missing all running gear). 2. It's his truck to do with what he wants. Cattlejoe, I'm not sure if the Jag will fit, but if you google (or measure) for the track width of the Jag, that should give you a good indication. | | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | Asked for information, not criticism. Like the other fellow said, It's my truck and I can do what I want with it. And, by the way, it was customized in the 60s long before I got it so it is so far from original it isn't feasible to restore it to original.
Like my mother used to say," If you can't say something good, don't say anything at all."
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Asked for information, not criticism. Like the other fellow said, It's my truck and I can do what I want with it. And, by the way, it was customized in the 60s long before I got it so it is so far from original it isn't feasible to restore it to original.
Like my mother used to say," If you can't say something good, don't say anything at all." Excellent response You'll get a some of those comments when discussing customization on this forum, there are a lot of restorers on here. When I first joined I didn't really discuss my truck for a while, but there are also some very accepting members and there are a lot of great folks and information here. While his is an earlier and probably narrower truck, you might want to have a look at this thread: Project XJ-PU | | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | Thanks for the link, I've done a few Mustang II and Camaro conversions but never a Jag. The measurements indicate it will work. I was just a little skeptical about using the later model Jag. All the information I've found, most are using the pre- 1988 suspension.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have done several inboard disc rears on a 57 and a 55 which gave a very nice driving/riding/handling vehicle. With this IRS the bottom frame lip can be heated and turned out which allows the whole Jag cradle to fit up in place. Have an outboard disc IRS in "the pile" but have not used it yet. It's quite a bit different than the older one so I'll follow your build with interest. Have not done a Jag IFS yet but will probably do so since my favorite IFS, the Pacer, is now extinct. Here's how one sits with the Jag/Pacer combo. [img]https://i.postimg.cc/Wt0NpXKJ/Chuck-s-55-006.jpg[/img][img]https://i.postimg.cc/XZcMSzXV/Chuck-s-55-007.jpg[/img]
Evan
| | | | | Joined: Oct 2015 Posts: 5 New Guy | | New Guy Joined: Oct 2015 Posts: 5 | Thanks for the information. Will keep a running update on the install. Pacer, haven't seen one of those in a while. My second wife owned the Pacer that Ed McMahon drove in the commercial for them. She bought it from Ed.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | A friend of mine had a TF on Jag suspension,it drove beautifully. I'm sure there's a fella here in the UK installing a later 88-on Jag set-up in his first series,i'll see if I can find a link. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Google jaguar IFS in a Chevy truck to see some installs I plan on putting one in my 52 Chevy truck I think I will bolt it in using the stock jaguar mounting points . Good luck keep us posted Robert
This is no longer fun
| | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Cattlejoe, was reading this old post, I would look into the s type or xjs rear, they have outboard disk brake disk, the xke have inboard disk which I think would be somewhat hard to replace and the e brake cable gets into the way of drive shaft, here is some good info rear end jag gives lot of info. Hope it helps Jbennett | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hi! I am new to Stovebolt and am thrilled at the wealth of knowledge on it. I am about to buy a 55 Cameo that is all in pieces. I have read lots about using S10 frame etc to get disc brakes/power steering. However, I have also read about pre-88 jag front suspension installs. A couple of questions: 1/ what is the best way to go i.e. S10 vs Jag? What would be the differences in the ride? Does one option cost considerably more than the other? 2/ I am assuming because I have not read anything that the rear end of the Jag could not be used for the rear end of the Cameo? (I am total newbe so please excuse my ignorance).
Thanks and have a great night! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Have you read the "Definitive Suspension List for Stovebolts" at the top of this Forum? Lots of good info there.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | If you want a vehicle that rides and handles like a Jag, wouldn't it be simpler and less expensive to just buy a Jag? It's also possible to make a silk purse out of a sow's ear, but it makes the pig look funny and it doesn't hear very well! Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I all I know about Jag front suspension that they are terribly expensive to repair. By the way, I have an AMC Pacer front suspension on my 1954 1/2 ton, that gets some raised eyebrows. Contact Mongo on this site he should have a lot of information in the s10 area.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Thanks WE b OLD.....i've heard of Plymouth Volare front ends being used as well. AMC Pacer that could be cool! Any pics?
HotRod Lincoln.....which Jag could i buy for ~$2500 US that they only made ~ $5000 of? Thanks for your input. I am a newbie just trying to get as much info as I possibly can. | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Coilover: I just saw 5 Pacers for sale for dirt cheap. How easy or difficult was the suspension change? I am assuming you only used the front suspension and putting something else in the rear end but am a newbie so please excuse my ignorance. Thanks and have a great day! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Before you go all gaga over the Pacers, check parts availability in the off chance something breaks later.
| | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hi! I am hoping to get pics of the 55 Cameo frame that has been apparently "butchered" by C-notching and install of Mustang IFS. Will post to anyone who is interested for your opinions as I am not familiar with either of these 2 processes. Thanks and have a great day! | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | If the Jags are that scarce, where do you plan to find a donor for the suspension system for your truck? I'd suggest buying the whole Jag from the salvage yard when you find one, restoring it, and then selling it it to a collector for a big profit to finance your truck project. Jerry
| | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hotrod Lincoln: my neighbour has a Jag he is getting rid of. I am not interested in restoring it but am interested in restoring my 55 Cameo......thanks for your help! Just looking at possible options for suspensions at this point-nothing definitive! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Borbas,the Jaguar suspension is a fairly popular swap for both first and second series trucks here in Blighty,obviously availability of suitable donor cars here is somewhat better thanks to our generous use of salt in the winter,our biggest stumbling block is LHD steering rack availability/price.
Fwiw A friend of mine has a front and rear Jag set up on his and drives the snot out it,he loves it,he happily cruises on the freeway at speed in excess of 70/80mph with no worries,it's pretty good in the twisties too.
As you say,it's your truck do as you please,i'd rather compromise a little originality in favour of something that's safer and also much more fun to drive. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Chassis Engineering used to sell a BOLT in mounting kit for a Pacer IFS front that left the entire Chevy front cross member in place.Since it now Heidt's I don't know if it's still an available kit. I have a 52 frame with a Pacer front and a Lincoln/T-Bird/Cougar IRS which I will take a picture of but not real soon---it's in a field and we got 13.5 inches of rain the last few days and it's raining now.
Evan
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm pretty sure the Pacer front end is what "we b old" is running under his 54. One would think they are hard to find these days unless its still available aftermarket. | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Thanks everyone for your help and advice.....still waiting for pics of frame and VIN # from owner's ex-husband. Once frame is inspected by my friend who is currently building a famous Anglia, I will know how bad it is or not and what direction I will be following re IFS and IRS. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have had the Pacer ifs in my 1954 3100 since 1985 and the only issue I have had I had to replace the original rack 19 years ago. information
| | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hi! Back again to the forum but still don't have frame VIN #'s for the 55 Cameo i am looking to buy....should have this in the spring2019. Anyways.....am looking at purchasing a 1991 S10/hot rad chassis with 107" wheelbase.....ha rebuilt from end lowered with new 3" drop spindles and all new bushings....rear end lowered 3" with four link and coil over suspension......comes with chevy 350, turbo 360 transmission and driveshaft......wheels and tires. Asking $1500. I am not familiar with any of this stuff so what should I be looking for in terms of quality of workmanship etc? How direct a fit would this be for the 55 Cameo body? Thanks for any help......very much appreciated. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | $1500 is VERY low for a quality piece. The 107 WB will be way short for the Cameo. Short answer, no it won’t even be close to a direct fit. Advise, if your going to do a frame swap, wait until you get the truck right in front of you. The tape measure will be your best friend. Also, the stock frame unless rusted out lends itself to suspension upgrades with lots of bolt/weld on kits available.ðŸ›
| | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Thanks Justhorsenround. The frame sold over the weekend. So 107 wheelbase would have been for an s10 short box? The original Camro frame may have been butchered beyond use as previous owner tried to install Mustang II front end and C-notched the rear......I have not yet seen this frame. ... | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | On the last couple of Pacer fronts we used the disc brake parts were replaced with Ford (nearly a direct interchange) and the A-frame parts work with Chevy 1/2T pickup so no shortage of parts. Ball joints are the screw in Chrysler which took fabbing up sockets. AMC (and International) used parts from other manufacturers to assemble their vehicles so it's just a matter of sleuthing them out. My 65 International 3/4 Crew Cab had Autolite electrical and a C6 automatic while others had Delco Remy electrical and Chrysler Torque Flites.
Evan
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hi guys! Finally back on here with some more info re frame from 55 Cameo. No pics yet but I have some numbers taken directly off of the frame. 255J008073 along the frame rail and 002 3713290. Does anyone know where I can check to see if these numbers would indicate the frame is in fact one for a 55 Cameo? I am still waiting for more pics of the Mustang II IFS install etc. Thanks in advance for any help.....very much appreciated. Have a great day! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 255J008073 255 = 2nd series 1955 (there should be a model code/letter before 255)? J = Janesville 008073 = probably 7073rd vehicle or model off the line that year? I thought that frame IDs were not used until 1956? Is there an ID plate between the hinges on the cab door frame? What code is on the plate? [from the earlier post - link is at bottom of this post: VH255B029380] [ V = 8 cylinder engine H = 2100 ] http://www.1954advance-design.com/chev-specs/1955-2nd-Chevrolet-t-ser.pdfIs there an Engine Serial Number pressed into the block to the rear of the distributor? on the body hinge pillar?Cameo was model 3124 Earlier post | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | Hi tclederman....thanks for the info. Unfortunately, neither of the engines that come with the truck are the correct/original ones.....one appears to be a Chev 350 and the other a Pontiac 400. "008073=probably the 7073rd vehicle or model off the line that year"......did you mean to say that it was the 8073rd vehicle off the line? I will see what other info I can come up with...... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If the code is an original 1955-2nd code, the serial number for the year. started at 1001, so, you subtract 1000 from the code you found.
Look at the link to identification codes that I posted above. | | | | | Joined: Aug 2018 Posts: 51 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 51 | ok thanks......new to this so finding out lots of info.....very cool/very informative. Much appreciated. | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | For those who wish to try this but prefer newer parts, some Lincoln and Thunderbird models came with 9" carriers and IRS. | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | Asked for information, not criticism.
Like my mother used to say," If you can't say something good, don't say anything at all." Ha ha, best response ever from a new guy! You should be safe from purist rants on the HiPo forum but evidently they troll here just to raise their own blood pressure. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Just an FYI, Cattlejoe last logged-in in mid November 2015. Jay Zed is absolutely correct. The HiPo forum should not be used to criticize folks for doing modifications to their trucks. That’s why it was created, as a safe haven for the hotrodders among us.
