2 members (BC59, 1 invisible),
152
Mod | | | Forums66 Topics128,088 Posts1,056,110 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | I have a problem with my 1950 3600. When it rains, water works its way through the center seam on the hood and drips onto the valve cover. The valve cover has slots or vents in it and then the water runs down into the crankcase. What is a good way to seal this center seam?
1950 3600 1951 4400 Gazz
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not a body/metal man but I think I'd pull off the center strip, run a nice bead of sealer down the middle and then reinstall the center strip....and of course put a dab of sealer where the anchors for the center strip come through.
.....I might ask, are you sure its from the center strip or is water on the valve cover coming from a mis-aligned drain hose for the cowl vent? Just had to ask. | | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | I first thought it was the cowl vent drain so I put an extra piece of hose on it to run it down to the side of the block. After rain, there is still puddles of water on top of the valve cover. How is the center strip removed?
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Gazz,
Sounds like you eliminated the cowl drain hose as a possibility. So, your center strip does seem like it is the likely area where the water is coming from. Your center strip is held in place by 16, 1/4 inch tabs. They fit into stots on both sides of the hood center seam. The tabs are off set about a 1/2 inch. If you open your hood, you should see them. They need to be straightened out, for the center strip to be removed. I like Achipmunk's idea of running a bead of good sealer down the center line and dabbing a bit in each tab slot. Hope this makes sense. If so, hope it helps you with your issue. Good luck.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | Took a look at the underside of the hood and I see tabs. Should be easy enough to remove. Hopefully I'll get to that today after I finish putting on the shake shingles on the new shed. Thanks for your replies and comments!
Keep us posted. Let us know if that fixes your water issue.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Seems odd to me that others are not having identical issues as you. Is the seam of the hood wet on the underside? Does this happen every time it rains, or just torrential head-on sideways downpours? I'm not doubting whether your valve cover is wet. I'm just suggesting further assessment before you go to all of the trouble of removing the center strip. Carl
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | i had the same problem , i ran exterior caulk down both sides of the center strip ,squeezed it in with my finger then wiped as much as i could off with a wet rag.it has worked for about two years. my truck was a faded light blue and the caulk i used was a light gray. if my paint was nice i'd match it better. but it stopped the leak | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...since the weather is getting colder may I suggest taking it easy on the tabs if removing the center strip. I learned a long time ago that "cold" things snap a lot quicker than hot ones. Take it easy if the weather up your way it cold! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm not a body/metal man but I think I'd pull off the center strip, run a nice bead of sealer down the middle and then reinstall the center strip.... I was having similar issues with the water getting onto my HEI distributor (V8) and forming nice puddles on my air cleaner top,this is exactly what I did Alvin,so all I need now is a hood strip!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jock, ole pal, order a new one, send it to my house and I'll see if Fed-X can get it to you! | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | jock i can't sent you a pm ....... it says you don't exist ?? UBB Message User not found Please click [ Back ] to return to the previous page. so here is a switch company you asked about some time ago http://www.elecdirect.com/catalog/cole-hersee-switches/cole-hersee-rotary-headlamp-switches
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | We do really need a better aftermarket heater switch solution. Some people do not have the original switch (which is far better) so thanks for the link. The problem will be trying to make the knob look stock or at least vintage. But thats called an obstacle! We can do it. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jock, ole pal, order a new one, send it to my house and I'll see if Fed-X can get it to you! Thanks for the offer Alvin,to be honest I can get one this side of the pond,i'm just lacking 'disposable income' at the moment.  Plus,having one sent from the States makes me think of pretzels for some reason.....what are the chances of a hood strip arriving intact?  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | jock
I can't sent you a pm ....... it says you don't exist ?? UBB Message User not found That's strange Jim,i'm still alive and kicking. (I think?)  Thanks for the link,to be honest the jalopy's got over 5500miles under it's belt now,I've got all the electrics buttoned up a long time ago,but that's a handy site for future reference. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ...what are the chances of a hood strip arriving intact? big_eek
i ended up getting three of them because the boys in shipping couldn't seam to get their acts together............ ho hummmmmmm
