4 members (PAUL Berardi, Simso, Gray_Ghost, JW51), 117 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
#1127855 10/04/2015 4:29 AM
I have a problem with my 1950 3600. When it rains, water works its way through the center seam on the hood and drips onto the valve cover. The valve cover has slots or vents in it and then the water runs down into the crankcase. What is a good way to seal this center seam?
1950 3600
1951 4400
Gazz
Gazz #1127862 10/04/2015 5:02 AM
I'm not a body/metal man but I think I'd pull off the center strip, run a nice bead of sealer down the middle and then reinstall the center strip....and of course put a dab of sealer where the anchors for the center strip come through.
.....I might ask, are you sure its from the center strip or is water on the valve cover coming from a mis-aligned drain hose for the cowl vent? Just had to ask.
Gazz #1127897 10/04/2015 3:29 PM
I first thought it was the cowl vent drain so I put an extra piece of hose on it to run it down to the side of the block. After rain, there is still puddles of water on top of the valve cover.
How is the center strip removed?
1950 3600
1951 4400
Gazz
Gazz #1127902 10/04/2015 3:52 PM
Gazz,
Sounds like you eliminated the cowl drain hose as a possibility. So, your center strip does seem like it is the likely area where the water is coming from. Your center strip is held in place by 16, 1/4 inch tabs. They fit into stots on both sides of the hood center seam. The tabs are off set about a 1/2 inch. If you open your hood, you should see them. They need to be straightened out, for the center strip to be removed. I like Achipmunk's idea of running a bead of good sealer down the center line and dabbing a bit in each tab slot. Hope this makes sense. If so, hope it helps you with your issue. Good luck.
Rugo
Steve Rugg
53 3100
Gazz #1127914 10/04/2015 6:26 PM
Took a look at the underside of the hood and I see tabs. Should be easy enough to remove. Hopefully I'll get to that today after I finish putting on the shake shingles on the new shed.
Thanks for your replies and comments!
1950 3600
1951 4400
Gazz
Gazz #1127917 10/04/2015 6:37 PM
Gazz,
Keep us posted. Let us know if that fixes your water issue.
Rugo
Steve Rugg
53 3100
Gazz #1127938 10/04/2015 8:56 PM
Seems odd to me that others are not having identical issues as you. Is the seam of the hood wet on the underside? Does this happen every time it rains, or just torrential head-on sideways downpours? I'm not doubting whether your valve cover is wet. I'm just suggesting further assessment before you go to all of the trouble of removing the center strip.
Carl
Gazz #1128125 10/06/2015 2:11 AM
i had the same problem , i ran exterior caulk down both sides of the center strip ,squeezed it in with my finger then wiped as much as i could off with a wet rag.it has worked for about two years. my truck was a faded light blue and the caulk i used was a light gray. if my paint was nice i'd match it better. but it stopped the leak
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Gazz #1128164 10/06/2015 4:44 AM
...since the weather is getting colder may I suggest taking it easy on the tabs if removing the center strip. I learned a long time ago that "cold" things snap a lot quicker than hot ones. Take it easy if the weather up your way it cold!
I was having similar issues with the water getting onto my HEI distributor (V8) and forming nice puddles on my air cleaner top,this is exactly what I did Alvin,so all I need now is a hood strip! grin
More pix on Flickr.
Gazz #1128317 10/07/2015 4:36 AM
Jock, ole pal, order a new one, send it to my house and I'll see if Fed-X can get it to you!
Gazz #1128697 10/09/2015 5:54 PM
jock
i can't sent you a pm ....... it says you don't exist ??
UBB Message
User not found
Please click [ Back ] to return to the previous page.
so
here is a switch company you asked about some time ago
http://www.elecdirect.com/catalog/cole-hersee-switches/cole-hersee-rotary-headlamp-switches
Jim & Caroline
Gazz #1128740 10/09/2015 11:47 PM
Gas Pumper
Gas Pumper
We do really need a better aftermarket heater switch solution. Some people do not have the original switch (which is far better) so thanks for the link. The problem will be trying to make the knob look stock or at least vintage. But thats called an obstacle! We can do it.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks for the offer Alvin,to be honest I can get one this side of the pond,i'm just lacking 'disposable income' at the moment. grin
Plus,having one sent from the States makes me think of pretzels for some reason.....what are the chances of a hood strip arriving intact? big_eek
More pix on Flickr.
Originally Posted by carolines truck
jock
I can't sent you a pm ....... it says you don't exist ??
UBB Message
User not found
That's strange Jim,i'm still alive and kicking. (I think?) grin
Thanks for the link,to be honest the jalopy's got over 5500miles under it's belt now,I've got all the electrics buttoned up a long time ago,but that's a handy site for future reference.
More pix on Flickr.
Gazz #1132521 11/02/2015 7:17 AM
here is what i did to fashion up my 'loook a like'' knob
http://s67.photobucket.com/user/1951otter/media/0A.jpg.html?sort=6&o=231
http://s67.photobucket.com/user/1951otter/media/1A-1.jpg.html?sort=6&o=230
http://s67.photobucket.com/user/1951otter/media/21.jpg.html?sort=6&o=229
http://s67.photobucket.com/user/1951otter/media/005_5.jpg.html?sort=6&o=224
i bent a metal strap 2x, drilled 2 holes to work with the new switch and old knob to dash threaded piece. connected them together with a piece of threaded connector 'coupler nut'' but i drilled into the coupler nut and threaded 2 allenhead set screws.
so
each end, the switch stem meet the knob stub and both are held inside the coupler nut by 2 set screws
i used the '' C '' knob for climate control. that's my heater switch
actually the new 2 speed heater switch was too fat to fit where I wanted it to be located so i had to devise this trick smile
Jim & Caroline
Gazz #1132522 11/02/2015 7:22 AM
i ended up getting three of them because the boys in shipping couldn't seam to get their acts together............ ho hummmmmmm
Jim & Caroline
