1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | what are the little v shaped piece that are attached to the inside of the windshield trim /molding .do you need them | | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | [m talking about a little piece v shaped that goes between the molding and the cab. it sltdes in the back of the molding . all I can think of is it was to prevent tighting the molding down to much | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You are correct they are spacers/anti-squeak, made out of a hard foam like material. I would think it would be a good idea to replace them with similar. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Any pictures of those? I haven't taken the inside windshield garnish off my '50 and it looks like it's collapsed in a few spots. dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Pictures would be good all my trim has been removed and I didn't find anything other than some dried up rubber I assumed was for anti-squeak, and a couple of spider nests. I defiantly don't have the trim pieces Brad posted, but I do like the look and will see if I can find some.
| | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | Any body have a pic of what the center clips attach to was there a moulding clip or what or maybe an Idea of how to attach them. My understanding is they come from {37 to 39 car} and {truck 48 and 49} not 100% sure, any feed back would be appreciated | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There were a couple metal type "spacers" on my 52 panel. From what I could tell it seems they went where the windshield defroster slots are cut in the trim/moulding. It will keep you from tightening the screws there and caving in the trim. ......I'm probably wrong but just my guess and that's what I did with the ones I had.
EDIT: I'm all wet here....miss read the question. Disregard my comments! sorry
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Jacksun,
Those little "V" shaped clips, or as mine were "W" shaped clips go on each side of the defroster vents in the molding to support the molding for strength. The area were the defrost slots are is open and much thinner than the rest of the inner windshield molding. Of course, these clips are no longer available....even after market, so I made new ones from the metal wires from paper binding clips. Just keep one of the old clips for a pattern.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Oct 2013 Posts: 15 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 15 | Hi Brad could you please when you have time send me a pic of the clip that you use on the top and is it identical to the bottom one I have 5 clips they look almost the same but they are a tiny bit different. thank you in advance | | |
