6 members (SmalltownTRKGuy, Otto Skorzeny, moparguy, Gdads51, dt235sd, 1 invisible), 76 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#1124952 09/19/2015 3:31 AM
Fox
Offline
Will Por15 applied to the underside of fenders be adequate to stop rock strikes from making stars in the paint on the shiny side?
Necessary to apply a rubber compound over top as well?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I would doubt it as there is nothing to "absorb" the energy from a flying rock....but something is better than nothing and POR15 is tough.
As Alvin posted, POR is tough.
That is what I have under the fenders of my trucks.
However, if you have a lot of gravel roads (and/or gravel that makes its way onto the roads), an additional layer of a rubber compound may add a greater degree of protection.
There is not much gravel up here in NY, but I am moving to NC and I hear the gravel when I drive down there. I might be adding a rubber-like undercoat to my Suburban (and to my other trucks that are not yet road-worthy).
i put por 15 on the fenders for rust protection. i then spray a good coat of 3m rubberise under coating over the top of the por. you can paint over the under coating if you want to match the truck
POR-15 will not prevent rock strike stars, I found that out the hard way. I would suggest some sort of rubber spray coating. I used one from Rustoleum, any brand should do, and it did make a difference. I haven't had any further issues with stars from rock strikes since I sprayed them.
Bill Burmeister
Fox
Offline
Beauty. Thanks fellas.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
