0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Will Por15 applied to the underside of fenders be adequate to stop rock strikes from making stars in the paint on the shiny side? Necessary to apply a rubber compound over top as well? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I would doubt it as there is nothing to "absorb" the energy from a flying rock....but something is better than nothing and POR15 is tough. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Alvin posted, POR is tough.
That is what I have under the fenders of my trucks.
However, if you have a lot of gravel roads (and/or gravel that makes its way onto the roads), an additional layer of a rubber compound may add a greater degree of protection.
There is not much gravel up here in NY, but I am moving to NC and I hear the gravel when I drive down there. I might be adding a rubber-like undercoat to my Suburban (and to my other trucks that are not yet road-worthy). | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i put por 15 on the fenders for rust protection. i then spray a good coat of 3m rubberise under coating over the top of the por. you can paint over the under coating if you want to match the truck | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | POR-15 will not prevent rock strike stars, I found that out the hard way. I would suggest some sort of rubber spray coating. I used one from Rustoleum, any brand should do, and it did make a difference. I haven't had any further issues with stars from rock strikes since I sprayed them.
Bill Burmeister | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
