| | | Forums66 Topics128,162 Posts1,056,960 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 24 'Bolter | | 'Bolter Joined: May 2006 Posts: 24 | Well, "Ethyl" is finally home, after being hospitalized for several elective cosmetic surgeries. Basically she got a total makeover, losing about 900 lbs in the process! You see, Ethyl used to be a big girl, a ton and a half if you can believe it! Found a military-issue (? - not sure) 1942 chassis and had all the driveline rebuilt, and any metal-to metal either rebuilt or replaced. Even found new (NOS) gears for the rare differential - from Canada! Wow. Installed an S-10 5 speed with help from Vintage Metalworks for the adapter plate and shifter extension. Decided on the practicality of a flat bed which got a lot of modifications to make it look more original. Inspiration was a Chevy dealer's 1946 advertisement photo. http://s1308.photobucket.com/user/JohnRTon/media/Rascal%20Ethyl_zps371ywwft.jpg.html?sort=3&o=0
Stovebolts are like women; as they mellow with age, it's harder to get 'em to turn over on a cold morning, but once they're warmed up, LOOK OUT!
| | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | John, nice job. I can hardly wait to see it with the bed on it. Keep up the good work and the pictures coming. | | |
