5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#112344 03/24/2004 4:35 PM
Hello Everybody,
I am in the dissassambly process of a 53.I was wondering if someone can tell me the correct name for the odd bolts that hold a lot of the truck together,you know the ones-almost looks like a figure 8 in a round head,and where i might find a socket set to remove them.Thanks,
Aaron :p
#112345 03/24/2004 4:47 PM
Aaron-
The technical term for these are "clutch head" screws and bolts. We have all had to find proper tools for these. I know that my local NAPA store sells a series of sized screwdrivers, still used for adjusting some carbs. Other tool companies sell clutch head inserts for ratchets and the like. Many suppliers for old trucks also carry these (I've seen them in the LMC catalog) Check with your local stores and ask for "clutch head" bits.
#112346 03/24/2004 5:49 PM
51PhatBoy,
Thanks I am going out to get them today.The visegrip-screwdriver-wd-40-blowtorch thing is not quite working out thanks again Aaron
#112347 03/24/2004 7:01 PM
Aaron-
Did you find some locally?
Search the Rust archives or other parts of the board for learning everyone's favorite method for getting 50 year-old rusty bolts to budge. I recommend PB Blaster rather than WD-40 before heat. Also, applying some force forward (tightening) before applying oil/blaster then removal seems to be a good mode. If you got a Stovebolt, you've spent time trying to coax these apart before they snap. grin
Good luck!
#112348 03/24/2004 8:10 PM
Welcome to another Utah feller, Aaron. Good luck with them there clutch head thingies. My trucks are a little newer (64 and 74) so I haven't run into that, else I'd offer some help.
Keep us posted,
#112349 03/25/2004 1:57 AM
Quote
Originally posted by 51PhatBoy:
I recommend PB Blaster rather than WD-40 grin
Mr. Chairman, I second this recommendation !!!
shoeless
#112350 03/25/2004 4:04 AM
Hello again,
Well I am back from my hunt for clutch head bits-drivers.No luck.Did find a set ai American Classic,screwdriver type I was after rachet type but beggers cant be choosers :DChevy asylum(Ray)I will likely see you at one of J.C.Hacketts gigs this summer-I will be the guy drooling grin since it will be quite a while until i can enter.Take care Aaron
#112351 03/25/2004 5:03 AM
Aaron-
Just saw your truck and story in the gallery. Nice rig! You should have fun tearing her down and sprucing her up.
#112352 03/26/2004 8:44 AM
Socket Breaker
Socket Breaker
My dad has a '53 chevy truck - and he had a time getting those clutch heads out. He finally got one out that wasn't too buggered up and we went up to the local Ace Hardware store(which is an especially huge hardware store) and showed them the clutch head... they had one of those six side insert heads, like the kind used in screwdrivers with multiple tips... usually used for going from philips head to flat... anyhoo, they had one. smile
We popped it into the screwdriver and it worked great. I think pop decided he did not like the lcuth head and replaced whatever it was with flat or philps head screws/bolts.
wink
-W
