8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Hello, I have had my 49 in a local shop for the last seven months. (I am not happy at all).. The guy doing the prep work for me said that the truck had enamel primer before and thats way they kept using that type of primer. He further advised that due to the type of primer and since he had to use a lot of bondo on the doors and fenders it will be better to use enamel paint insted of base coat clear coat, because enamel will cover everything better. He also advised the I could not use catalist primer in top of the enamel primer, can anybody clear this up for me thanks in advance... | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Is this where MARTINSTAR says, "pick a paint system and follow the manufacturer directions"?
HA!
I wish I could help but i really don't have any idea.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Doesn't sound right to me... I would think you should be able to use a sealer over the old primer... I've never dealt with this, I usually take 'em down to bare metal. I disagree with the thought that enamel covers better than basecoat/clearcoat. A finish is only as good as what you put it on. Maybe he's not experienced and color sands and polishes the final enamel finish to rid it of the flaws... How much bondo did he use? Maybe he needs to invest in a hammer and dolly... Just my $.02 worth.
A man is like an old truck... He will rust out before he wears out...
| | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Ditto factorybrook! A good sealer is worth the money! I thought that the problems were acrylics over lacquers..?? | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | the guys full of it if you use a two part primer sealer you can overcoat with urethane and clear if you want or enamel urethane is just enamel with a hardner added sounds like the guy dont want to paint your truck id get it out of there talk to some painters in your area | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | no you cant over coat with lacquer it will melt whats under it you would need to use a lacquer primer under it lacquer is old tec. no one uses it anymore not even on show paint | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Get your truck outta there. He's wasting your time, money and you'll end up with a finish that you are not happy with at all. Besides, it sounds like the jobber doesn't want to do it either... 7 months?
Andy
| | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Sea Dog, where are you located?
| | | | | Joined: Oct 2004 Posts: 18 Junior Member | | Junior Member Joined: Oct 2004 Posts: 18 | I have to add to this one. My truck went to the shop sanded to bare metal. I was told 4-6 weeks. Well 4.50 months later it finally came home. They used a catalyst primer, and CCBC. Looks good. It's in the gallery page (Don Graham) It's the stock Grandpa looking yellow and white '71 fleetside. http://www.stovebolt.com/gallery.htm | | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Thanks for all the input (am in miami, fl.) is not easy to find people that want to work in this trucks. I went by the shop yesterday and spoke to the owner of the shop he advised that the primer that the truck has now is lacquer primer. He further advised that he could use ppg k38 catalist primer. I am going to take the truck out of there for sure. Do you guys think I should wait for the k38 primer..thanks | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Any shop worth anything would not want to put a new coat of paint over unknowns. It takes a lowlevel shop person less than a day to take the whole truck down to bare metal with the proper sanding discs and a variable speed polisher/sander. Now he can finally assess how much metal repair the truck needs. Only then should he be thinking about fillers. He can then use any brand primer and finish coat he wants.
Stop the work. Ask him how much for the work he did so far. Come to an agreement. (He has you by the shorthairs). Then find a real shop.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Have you looked at any of the cars he's done in the shop? If you like what he's done, then don't run off to quick. I've had two trucks done with a single stage paint. Acrylic Urethane is very durable and doesn't use a clear coat. Now that I've had two trucks with a single stage I acually like them better. Easier to touch up also. Maybe this is what he's calling enamel. You will have a heavy price to pay if you take it out. The current shop is going to sock it to you for not letting them finish the job and the shop you take it to is going to want to start over because they will not want to trust what someone else has done. If you like the work that the current shop has done to other cars then I would leave it there. If he bothchs the job, then you can take him to court and get your money back, maybe..... Think about it and try not to get the shop mad at you. Try to work with them, even if you decide to take it out. Cecil.... | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | square up with him get it out of there a sealer can be put over that primer but dont let him do it you would get a better job at maaco 399. special | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | if you do leave it there agree on a finish date and stick to it what he well tell you next is he will need more money to finish it its taking more than he thought let us know how you come out | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | This is why I learned how to do body and paint work myself. I got tired of paying big bucks for shoddy work. Get a compressor and gun and go for it.
Body shops suck!
delete my account and pictures
| | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Well I went by the shop yersterday and bi*** the heck out of the owner and he is going to shot it with PPg K38 primer he promise the truck in two days. And if he cant deliver I will take the truck and pay him 30 percent less of the agreed value... | | | | | Joined: May 2003 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 47 | Well I went by the shop yersterday and bi*** the heck out of the owner and he is going to shot it with PPg K38 primer he promise the truck in two days. And if he cant deliver I will take the truck and pay him 30 percent less of the agreed value... | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | did you get your truck back | | |
