3 members (TUTS 59, ShopRag, 1 invisible),
106
Mod | | | Forums66 Topics128,089 Posts1,056,362 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | Hi all, Started cleaning the leaf springs from my daughter's 1959 Chevy 3100 and was wondering if this shape of the eyes on the front springs is normal? Saw a couple of pictures on the web of newer looking springs with this shape-- so wondering if these need replacing or just rehabilitation? http://s77.photobucket.com/user/cdc...ngs_zpsztjwfppv.jpeg.html?sort=3&o=0Thanks, Chuck | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Are you talking about the shape of the eye where the bushing is inserted? If a new bushing fits somewhat securely, you will be fine. If the pin wore through the bushing and into the spring enough to prevent a snug fit, you would be better off with a new main leaf spring. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | Thanks guys- the eye itself appears to be serviceable, I was just concerned about the outer spring wrapped in an unusual shape. | | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | I was more concerned with the shape of the outer spring wrapped around the eye.... | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | The second leaf is just a safety wrap around the top ( main ) leaf in case the top should break. Both look good enough to rebuild.
Joe | | | | | Joined: Sep 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 36 | | | |
