1 members (Hotrod Lincoln), 126 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
Hi all,
Started cleaning the leaf springs from my daughter's 1959 Chevy 3100 and was wondering if this shape of the eyes on the front springs is normal? Saw a couple of pictures on the web of newer looking springs with this shape-- so wondering if these need replacing or just rehabilitation?
http://s77.photobucket.com/user/cdc...ngs_zpsztjwfppv.jpeg.html?sort=3&o=0
Chuck
Are you talking about the shape of the eye where the bushing is inserted? If a new bushing fits somewhat securely, you will be fine. If the pin wore through the bushing and into the spring enough to prevent a snug fit, you would be better off with a new main leaf spring.
Carl
Thanks guys- the eye itself appears to be serviceable, I was just concerned about the outer spring wrapped in an unusual shape.
I was more concerned with the shape of the outer spring wrapped around the eye....
The second leaf is just a safety wrap around the top ( main ) leaf in case the top should break. Both look good enough to rebuild.
Joe
Thanks Joe!
