1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
Moderated
Moderated
Hi
I want 15" rims for my 8-lug axle. Was there an factory regular non-split type rims of that type. I'm looking for the older variants. Not modern types. I have seen pics so I know they exis, but I don't know on what type of truck they came on.
Did Chevy ever had them?
Magnus
I found a great 16 inch rim off a Ford Econoline van that bolts on a has a center area that will accept the Chevy 3/4 ton hub caps. This has been an ongoing problem and it does not appear that GM had a wheel that you are wanting.
I also thought about knocking the centers out of the old split rims and having them welded to a modern outer rim but after finding these 16 inchers gave up on that idea.
Best of luck
1946 1/2-Ton Chevy
Crusing in the Passing Lane
Do you want 15's in particular? 16's are easy to get tires for, at least over here.
In order to mount a tire on a one piece rim, the rim needs a
dropped center. Because of the dropped center the ID of the
rim is much smaller than that of the 15" two piece rim. If you
tried to use the center from a two piece rim in a 16" tubeless rim,
it would have to be cut back from 14.25" to a little over 13".
This would remove the support flange from the two piece center
and result in Tee joint where the center is welded into the
new rim. This is a bad design and will eventually lead to
cracks at the Tee joint. If you look at the centers of most
rims they will have a flange that is pressed into the rim and
a lap weld to secure it. There is very little load imposed on
the weld, most of the stress is transferred thru the formed
flange to the wheel center.
Here is a 15" two piece center compared to a 16" Ford tubeless
rim.
http://www.pbase.com/dennygraham/image/161147883/large
dg
Denny G
Sandwich, IL
The 3/4 ton 8-lug rear should the same as the 1 ton front. The question really lies in: "Will it fit over the brakes?"
I know a 16" rim would be a tight fit for mine (original drums), thus I have 17's.
IIRC, GM didn't offer 15" rims for 8-lug axles, at least on the Advance Design trucks. What year truck are you looking at?
Dave Baird
1951 Chevy 3803
Dave, the 3/4 tons did use a 15" 2 piece wheel on single wheel trucks at least to '59, maybe a little later (I'll have to check to be sure). While the axle is the same, the 3/4 ton uses smaller rear brakes.
Bill Burmeister
Moderated
Moderated
Thanks guys. Seems like there is no stock option for me. I have a pair of 16" wheels, but I rather have 15" because of a particular tire I want to use.
I'm pretty sure I have seen 15" regular wheels with 8-lug centers. But they could have been custom made of course. It wouldn't be difficult to take the centers out and turn them down to fit a 15" rim.
I will continue the search and if I can't find anything I will go with 16"
Magnus
Just out of curiosity, what kind of tire are wanting to run? For the most part, most modern 15" tires are going to be too low of a capacity rating to handle a 3/4 ton truck, with maybe the exception of the LT 235/75/15, which is a 6 ply rated tire. Is the tire you're looking at available in other sizes?
Bill Burmeister
