11 members (hapydirty, Southerntruck, klhansen, 78buckshot, Otto Skorzeny, D B Cooper, Peggy M, Jims46, Hawkman, manymiles, MikeE),
100
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Got my whiskers lined up with the holes, now how do I bend those staples over right and tight the first time, thanks HUGH | | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Got with 3 pair of vice grips and a wood block and super tight too, and no boo boo's.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | What year truck are you working on? Are they new reproduction or original? Mike B  | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | This is for my 1952 Chevy truck 1/2 ton, and the whiskers are repro. One door down and one to go. A lot of good info here. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Them staples are hard. I used a combination of tools. First issue was to locate the holes. Then I used needle nose pliers to start the bend and a body dolly to prevent the staple from rotating with the pressure. Finished, with 2 pair of vise grips. 1 to hold the staple flush, and 1 to finish the bend. What I did do to keep the stable was a bit of 3M adhesive(black weather strip) on the back side. They won't move after that sets up. I was not expecting the staples to bee that stiff. The old ones were soft and came out rather easy.
Steve H
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Ok, new guy here... what are we talking about because it sounds like I need to pay attention (the "no boo-boo" part)
Brad Wrench Fetcher, PhD | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | I was referring to boo boo's as no scratched paint, no bent metal frame, and still got my fingers and skin, also the staples went down straight and secure the very first time. Make sure to use a wood block on the opposite side and use needle nose pliers to start the bend and a pair of vice grips with a lip to clear the frame and bite the staples hard and true and watch your fingers. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Does anyone have pictures of this part of the assembly, my window felts look strange when lined up on inner trim piece.
didn't come with staples ,will glue work? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | hacker, I used the 3M weather strip adhesive on my 52panel about 3 years ago. Still holding up nicely. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Which 3M # adhesive, ?
Also, shape of whisker seems odd, does anyone have a picture? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | And if DG didn't have so much yard work to do, he would have made the giant nuclear powered stapler similar to what GM used for those staples.  Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not for a couple of trucks Carl, but I did make the staples using SS aircraft safety wire. Soft and is easy to close with the reworked jaws on a pair of cheap HF pliers. Get them started with needle nose then close them with the reworked pliers.
dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | This answer may be a little late for the original poster. Here's how I bent the staples to attach fuzzy wipes to the window garnish in my '54 ... < CLICK >- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | One correction I noticed in a reply Lonnie. You said that won't work on the single piece window doors. Sure it will, my '50 has single piece windows, i.e., no vent window. Maybe that's why I ground the special shape into the pliers jaws.
dg
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | That's correct, Denny. I believe that the locking pliers from Lowe's are too thick to fit a non-vent door without grinding the jaws thinner. (I'm relying on my old dull memory as I type this, so take it with a grain of salt.)
I have some pre-51 window garnish but it's boxed up, so I can't confirm my statement.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Found an old photo of garnishes for doors without vent windows (left) and doors with vent windows (right). More room for pliers to bend the staples in garnish for doors with vent windows. > '47-'50 on left, '51-'55 on right- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Denny,Lonnie thanks, the pcs I received do not match the trim, so I will bend them to match and attach. Then I have to get brave enough to get near newly painted truck....
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Whiskers from The Filling Station have the correct bend.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Lonnie, wish I had known that before, but these will suffice. still trying to decide between staples as Denny made or glue as achipmunk said.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If you get the ones that aren't bent....send them back!!!!! When you try to bend them they will open up and the felt will come out of the crimp. That's what the pictures of the bending jig is in my album. In order to bend them correctly the bead needs to be restrained from spreading apart.
dg
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | they came bent, but do not match trim piece | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | With out a picture, it's hard to tell just what you have.
dg
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | The bends were about 1 1/2" inboard of the bends on trim pc,
| | | | | Joined: Aug 2013 Posts: 4 New Guy | | New Guy Joined: Aug 2013 Posts: 4 | I just finished the passengers side door replacing the outer rubber, whiskers and the window channel. The whiskers that came were straight but I carefully and slowly bent them with a good set of pliers. When I was done it matched what was there which I believe was original. That means the chrome beads and fuzzy stuff between looked like the original in a staggered finish; longer on the inside radius and shorter on the outside radius. I'll take pictures of the drivers door when I do it. I attached the whiskers with very small screws. I held it in place and drilled a hole through the whisker and into the trim in roughly the same location the staples were. The screw had a small head and when I tighten it down it buried itself in the felt and you can not see it. The screws were about 3/16" long.
RW “Do what I do. Hold tight and pretend it’s a plan!” ~ Dr. Who ~ | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Since being all original is not important to me I came up with a simpler plan. My whiskers are just a piece of hook fastener. As in ; " Hook &Loop ". Cut to length and applied. Then trimmed the top edge to get the radius look. Worked just fine and no window rattles. 3M adhesive on material holds tight. Just a thought for anyone who is not that fussy to go through all the attachment process of the stock piece.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Feb 2012 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 44 | I just used small pop rivots. worked for me | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | with plenty of access to 3M products, I should have looked at that option, and have some of that product in my sample kit | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jacksun and just-a-hacker, over the years I've glued them, used staples and screws along with pop rivets. I love the 3M glue but also like rivets. I've found the 1/8" rivets are just to big for me personally and wonder if anyone, maybe you Jacksun, had used the 1/16 size. Do they hold good enough??? Hard to find the 1/16 unless you order them. I figure a couple SMALL ones and some 3M the process would go even better. Jacksun, did you use the 1/16? | | |
