7 members (Steelonsteel, dt235sd, klhansen, Charles in CA, BarryP, Wally / Montana, 37 GC),
139
Mod | | | Forums66 Topics128,142 Posts1,056,782 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I had to buy new retainers. Is there a rubber strip that this retainers holds to seal the bottom part of the door? I can't seem to find any pictures. Thanks in advance.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Alvin, Yes, your first picture is the "lower door seal retainer" I'm trying to figure out. Does the lip on the retainer hold the door weather stripping? Or is there supposed to be something else. Looks like yours strip holds the rubber?
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | That retainer holds the bottom of the door seal which goes all the way around the edge of the door. There is not an additional seal under it. The retainer really squishes the crap out of the bottom of the door seal. Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The first one was a booger then I figured it out. I did put some 3M weather stripping adhesive to hold the seal. I don't want it falling out....EVER! The after market metal pieces are good but there was a trick to putting it on. If you study it a little you can figure it out. I put one screw in the end and then one in the opposite end and then "every other one" until I had them all snugged up. They are a little hard, or mine was, to pull down "into" the rubber. That's why I put one screw in it with the metal piece up "high" a little. Then pulled it down into the rubber. There is a thread from back then if I can find it that explained it better than I am now. I can't remember it all right now. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Alvin / Carl, Thank you. Thats it, it holds the bottom of the door seal, no additional rubber piece to stand on my head getting to work.
