5 members (Phak1, 68ironhead, Ridgeback, Wingnut68, Joe H), 109 guests, and 1 robot.
Topics128,196
Posts1,057,398
Members48,471
Does anyone know what size lines and what types of flares we need?
1953 GMC 1-Ton Pickup with 350 and 700R4
45° double flare, with male threaded tube nuts, they fit in "inverted flare" fittings.
Originally I know it was 1/4" line for most if not all, and if not for everything then there was some 3/16"?? It's been about 11 years since I replaced mine and I went with a different configuration with disc brakes. Perhaps someone else can recall exactly what size line where, if any 3/16 was used.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks! Does anyone have a source for rebuilt or new wheel cylinders for a 53 GMC 1-ton? Or do most guys rebuild theirs?
Im pretty sure Rock Auto carries both the kits or new cylinders. Make sure you check the size bore you need to make sure your getting the right size. I believe others have also mentioned Napa as well.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Moderated by  Dusty53
